Question about ViewSonic VA712 17" LCD Monitor
Power on then back light on then off what is the problem in inverter
  • 11,361 Answers
Here is the service manual: http://ftpkuban.com/FTP/Manual/ViewSonic/va712-2_sm.pdf
You need to verify that you do have steady 5vdc and 12vdc first, the problem can be due to bad caps, failed transistors/IC or inverter transformers, or worst cas the lamp assemblies.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 16, 2010
What would cause a black screen on vizio LCD Tv? I have sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 14, 2017 | Vizio Televison & Video
LG tv 55GA6400 has sound but picture keeps going black after a minute or so.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 13, 2017 | LG Televison & Video
Vizio tv 37" picture started to get darker
Jan 11, 2017 | Vizio Televison & Video
What is wrong with my TV? No picture but has sound. picture shows with flashlight.
Jan 08, 2017 | Televison & Video
Screen is black but led power lights come on ,yellow/green
Sounds like back-light inverter fault. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Mar 14, 2016 | Televison & Video
LG50LN5600ui. Where is backlight inverter board located?
To modern sets, with LED based back-light system, the back light inverter will be a part of the main power supply regulator board. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 10, 2015 | Televison & Video
Sound but no pucture
Nov 21, 2015 | Televison & Video
When I turn on the power the screen will light up briefly then go off, then the standby light goes on (red) and flashes in four times flash intervals
4 blinks notifies the back light failure . could be the back light inverter board or faulty capacitor on power supply board.have added the image of back light inverter. Also added the picture of the power board. On the picture the capacitors marked with red should be replaced first. If shows the same complaint even after that then you have to change the back light inverter board.
Power supply
Back light inverter board
25849195-rpi3jfilu1hke134nfog5c4e-2-9.jpg www.electro-medical.blogspot.com
Sep 04, 2015 | Sony KDL46V2500 46 in. HDTV LCD Television
VIZIOP42HDTV10A . It hadn't picture mean black screen , but hear sound from every channel and all another devices input
hi, Your tv has problem with its back light inverter stage. All LCD TV have back light to illuminate the pixels. There are two types of back lighting CCFL(Cold Cathode Fluorescent Lamp) and LED. In your tv its ccfl. As it is ccfl it need a high voltage above 1000v. To provide such a high voltage there will be an inverter stage in all lcd tv with ccfl back lighting. Normally in LCD tvs there will be three boards such as Mother board , Back light inverter board, and power supply. In your tv the ccfl back light inverter stage is faulty. There will in inverter transformers in the inverter board. As it is high voltage transformer there is possibility of its winding get shorted. If so it will drain a high current from the power supply and the protection circuit will shut down the voltage to the inverter board. check the inverter board first. Also there is possibility of bad electrolytic capacitors in the inverter board will lead to this type of problem. First of all check the supply voltage from the power supply to the inverter board. Change the electrolytic capacitors in the inverter board and in the power supply stage. If the problem is not rectified then you have to replace the inverter board. ok
Jun 10, 2011 | Vizio P42HD Television
ViewSonic VA712 17" LCD Monitor Logo
98 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
