Question about LG WM2277H Front Load Washer
Showing a code OE Washer will not finish cycles
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.You are right OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
Whats the red key and circle llso shows a OE code on LG steam washer wm2487hwm
OE on the LG means the washer is not draining or has a draining issue. When it happened to me I started by manually draining the washer and then running a spin cycle. In a pinch the work around was OK but I could never be certain the wash was complete. Also the wife hated it.
Finally, I dug in and went for a fix. All the hoses were clear and the pump seemed to be working (also the pump screen needed clearing). I found the problem to be a breather hose that runs from the top of the drum to one of the drain hoses. It was plugged and I took it off and blew it out. Problem solved.
Aug 05, 2012 | LG Washing Machines
Every other load we have OE coming up, also the drowm will not spin
LG washing machine error code - OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc
Nov 28, 2010 | LG WM2277H Front Load Washer
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Error code OE will not finish cycle
Hi
Thanks for using FixYa. A fault is detected in the water level sensor. Data (frequency) shows the water level is at or above the overflow level. Try entering the service mode by pressing the Spin and Temperature keys for three seconds or until the control beeps.
NOTE: The washer must be ‘ON’ before Service Mode can be entered.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Maytag Neptune MAH9700 Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
LG WM2277H Front Load Washer Logo
82 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
