Question about Franklin Industries FBC360D Beverage Cooler
I plugged in and it did not get cold for one hour.
  • 17,129 Answers
Allow it to work for some more time 2 hours and if there is no cooling at all, then your compressor needs a check. If the set is old can the gas have leaked off.?
These two factors must be checked out , the compressor and gas..
Posted on Sep 16, 2010
Model # 253. How long does it take to get cold?
was it laid down in transport if so it has to be left unplugged ofr at least 24 hours to allow oil to return to the compressor . quite likely you have already ruined the compressor
Jul 07, 2015 | Kenmore Refrigerators
Tip
Easier starts in the cold temps.
If your getting hard or no starts in the winter/cold temps cycle the glow plugs 2-3 times. They are programmed to cycle up to 120 seconds or 2 minutes which in some cases isn't enough. Turn the key to ignition (not start) and allow the plugs to heat for about 90 seconds then back off again. Do this 2-3 times and your diesel should fire up. If extremely cold plug it in for an hour which should be enough to assist in starting.
on Nov 11, 2011 | 1997 Ford F350 Crew Cab
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
I bought a danby fridge dff280wdb at an auction it was not plugged in but is new with all the tags . i had to lay it on it's back to bring it home but i let it stand for 3 hours before plugging it
I would suspect there is no refrigerant in the system any more. Sounds like there was a leak (hissing and odor). Not worth getting it fixed if that is the case.
Feb 03, 2013 | Refrigerators
Food in freezer are thawing and fridge doesn't feel very cold
hi there.well difficult without avisual but try a few tips ok?1-plug in and wit 1/2 hour first 2-still dead tap the stat.still dad and no noises at all check if motor hot or cold.i assume is frost free and if motor cold then it could be mechanical defrost timer or pcb.good luck Ali
Aug 26, 2012 | Whirlpool Refrigerators
Fridge is not keeping the food cold, water at the bottom of fridge, freezer is not as cold, still freezes things but takes a long time. This is a Kenmore 20 fridge, my guess is 15 years old.
unplug the fridge and leave the doors open for 48 hours, then see if your problem is gone 24 hours later after you plug it back in, if it is, your fridge needs to have a repair to the defrost side of things, most likely the defrost termination therm or the defrost timer, also make sure the drain under the evaporator is not plugged up
Jul 22, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Not blowing cold air
unplugged the unit, kept the doors closed about 10 to 12 hours plugged back in and in about 2 hours started blowing cold air into freezer another 4 hours was blowing cold air into refrigerator and continuily got back to the themostat settings,about 1 day. no food was lost because the doors were closed still keeping it cold. i think the fan in the freezer was frozen with ice,but could access it, not the main fan in the back the unit by the compressor,that was running fine. so basically i defrosted the freezer fan by unplugging it. this is the 2nd time in 4 years ive done this, well it beats spending 1000-1500 dollars to replace it TRY IT I HOPE IT WORKS FOR YOU BEFORE YOU CALL FOR SERVICE,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
We move my refrigerator and it was laid down for about 2 hours we plug it up when we got home now it won't get cold, how long will it take to start getting cold it been about 2 days now
It shuld never be layed down for transport or storage. 2 Hours is not a long time but you should have left it upright overnight before plugging in. turn it off for 24 hours. When you restart it it should be cooling in a few hours and at normal temp in 24-48. If not you may have damaged the compressor. (Assuming you hear it running)
Eric
Dec 23, 2009 | Kenmore Refrigerators
THE GLOW PLUG TURNS ON WENT ENGINE IS COLD
Yes it does. Let the glow plugs warm up for 7-10 seconds (the light on the panel should go off) and then crank the engine. If the weather is cold, half an hour of running does not warm up the engine completely so you need to use the plugs for the first few startups during a cold day.
Dec 17, 2008 | 1995 Mitsubishi Montero
Kenmore Coldspot Model 71182101
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Jan 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Franklin Industries FBC360D Beverage Cooler Logo
Top Franklin Industries Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
