Every now and then it prints out an encrypted page?
    Scholar:
  • 179 Answers
There is a place such as buffer where false pages r kept.. remove the pages frm there..
Posted on Sep 16, 2010
Canon Pixma MP490 illegible
if there is enough ink , print a test page if same problem is there check printer's setting ..
or re-install the printer ,ah sometimes the files are encrypted wen u print it will not be print out properly...
Nov 29, 2011 | Canon Office Equipment & Supplies
Print is encrypted, nothing is readable.
If you are printing it from online, try copy and pasting the content to Word or Excel and print from there.
Oct 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
Tip
How to print encrypted PDF
Many PDF files sharing online are protected with owner password preventing them from being copied or printed.Sometimes we need to print the for further use but fail.
In order to resolve the problem, you can remove the restriction by using this PDF Password Remover. It can change the encrypted PDF to a normal one with all elements preserved.
on Mar 05, 2010 | Computers & Internet
Tip
Installation CD for the print server
If you are having trouble going through the setup process on the installation cd do the following:
  1. Disable any encryption settings on your wireless router.
  2. Disable MAC filtering.
If these features are enabled during the installation setup process, the wireless features will not work unless you go into the admin settings of the print server by typing the IP address into internet explorer. Type in the correct encryption settings.
Linksys has a provision in the setup software to key in the correct encryption however the software doesn't put the information in properly. This will cause the wireless not to work and allow the print server to work only when it is wired to the network.
Encryption settings have to be entered through the administration settings of the router by typing in the IP address of the print server using internet explorer.
on Jul 20, 2008 | Linksys WPSM54G Print Server
It wont print wireless
We have to connect the printer to the network first, If it is not connected, please follow the below steps.
  1. Touch Setup (c01629002.gif ) on the touch screen.
  2. Scroll down in the Setup menu, and then touch Network .
  3. Scroll down in the Network menu, and then touch Wireless Setup Wizard . The Wireless Setup Wizard searches for networks, and then displays them in a list.
  4. Touch the name of your network.
  5. If the list does not contain your network name, follow these steps to enter it manually:
  6. Touch Enter New Network Name (SSID) .
  7. On the on-screen keyboard, touch the appropriate letters and numbers to enter the network name (SSID). NOTE: Make sure that you enter the uppercase (capital) and lowercase (small) letters exactly. Otherwise, the wireless connection fails.
  8. When you finish entering the new network name, touch Done , and then touch OK .
  9. Touch Infrastructure , and then touch WEP encryption or WPA encryption. If you do not want to use encryption (a security password), touch No, my network does not use encryption , and then go to step 6.
  10. If prompted, enter the WEP or WPA key:
    1. Touch the appropriate letters or numbers on the on-screen keyboard.
    NOTE: You must enter the exact uppercase and lowercase letters. Otherwise, the wireless connection fails.
  11. When you are finished entering the WEP key or WPA key, touch Done and then touch OK to confirm. The product attempts to connect to the network.
Once it is connected to the network or if it is alreday connected, please follow the below steps on the printer.
  2. Touch Network , touch View Network Settings , and then touch Print Network Configuration Page .
After that, please note the ip address of the printer from this printed page and follow the below steps.
Please click on Start------Control Panel---Printers Folder.
Right-click on the printer icon 8500 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
The issue will be fixed.
Apr 19, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do i find the network key on a netgear1004 router please? thank you.
you have to hook up thru the ethernet first.......to the computer from the netgear.........once connected go online in your browser...in the address bar type in this exactly 192.168.0.1 and then hit enter, you will see a small login screen user/login= admin, and password=password. now you should be looking at the router configuration page......there will be a tab or button that says wireless settings .....click it. you can change the SSID to a name you can recognize when "viewing available connections", scroll down and select wep 64 bit encryption, scroll down to where a box labeled key 1 is ...........in the box next to key 1 type in a 10 digit encryption (area code and phone number usually works great) and then click apply or save, usually located at the bottom of the page. once the page refreshes , double check your new settings to make sure they were saved...sometimes a router will force its own encryption and maynot save your 10 digit code in key1, if that happens just right down the code that is in it and you should be good to go. close out of all that stuff, pull out the ethernet cable and try to "view available wireless connections", you should then see your new SSID and click to connect with your new 10 digit encrytption code. also some routers have the default encryption code printed on the bottom of the router in a UPC type barcode with the numbers, it will say security pin or something close to that. its not the device mac or cmac.
Jan 17, 2010 | Gateway Wireless-B Router (wbr-100)
Reposting my sign in.
This will help, rate me fixya. thanks. Passwords
  • Remember passwords for sites: Firefox can securely save passwords you enter in web forms to make it easier to log on to websites. Clear this checkbox to prevent Firefox from remembering your passwords.
    • Even with this optionpreference checked, however, you'll still be asked whether to save passwords for a site when you first visit it. If you select Never for This Site, that site will be added to an exceptions list. To access that list or to remove sites from it, click the Exceptions... button.
  • Use a master password: Firefox can protect sensitive information such as saved passwords and certificates by encrypting them using a master password. If you create a master password, each time you start Firefox, it will ask you to enter the password the first time it needs to access a certificate or stored password. You can set, change, or remove the master password by checking or unchecking this optionpreference or by clicking the Change Master Password... button. If a master password is already set, you will need to enter it in order to change or remove the master password.
2.0:
  • Show Passwords...: You can manage saved passwords and delete individual passwords by clicking the Show Passwords... button.
2.0 3:
  • Saved Passwords...: You can manage saved passwords and delete individual passwords by clicking the Saved Passwords... button.
Warning Messages Click the Settings… button to configure the security warnings Firefox displays while you browse the web.
Security Warnings Dialog
  • I am about to view an encrypted page: When this optionpreference is enabled, Firefox will notify you every time you are about to view an encrypted page.
  • I am about to view a page that uses low-grade encryption: With this optionpreference enabled, Firefox will warn you when you visit a page which uses low-grade encryption.
  • I leave an encrypted page for one that isn't encrypted: With this optionpreference enabled, Firefox will warn you every time you move from an encrypted page to an unencrypted page either by selecting a link on the page, selecting a bookmark or typing a new address into the location bar.
  • I submit information that's not encrypted: When this optionpreference is enabled, Firefox will warn you when you submit data via a form that's not encrypted.
  • I'm about to view an encrypted page that contains some unencrypted information: With this optionpreference enabled, Firefox will warn you when the page you're viewing contains a mixture of encrypted and unencrypted content. If an encrypted page contains unencrypted data, you should verify the identity of the page you're viewing prior to entering sensitive data.
Mar 26, 2009 | Mozilla Firefox
D-Link DP 311U wireless setup
Had same problem. Got it to work!!
I have DLink DP-311U and 2Wire Gateway router/modem 2701HG-B.
Solution: Connect DP-311U to router via network cable.
Then you can see it either with PS Admin or with browser http://192.168.0.10 should be default IP address of DLink Print Server. Set Connection Mode=Infrastructure, ESS-ID=2WIRExxx (xxx is your number of the router) - this is your network name, and wireless channel=1.
And the most important - change your IP Address to 192.168.1.xxx - xxx=choose a number over 64 if it's not taken already.
On your Gateway page: http://gateway.2wire.net/xslt?PAGE=J46&THISPAGE=A02_POST&NEXTPAGE=J46
Set Network Name=2WIRExxx, WIreless Channel=1, enable SSID Broadcast, Disable wireless network Security.
Once you get those numbers in, check connectivity with above programs with cable connected, or typing new print server IP address in browser. Then disable cable and check again. You should be able to see the box. Then connect print server to printer and make sure your printer settings on computer point to new IP address.
Feb 09, 2008 | D-Link DP 311U (DP-311U) Print Server
k24674
