Question about Frigidaire Kitchen Ranges
Do all electric stoves have fuses? my oven quit working and i was told it could be a fuse.
3 Suggested Answers
zazonker
  • 68 Answers
SOURCE: kitchenaid oven kdrp467kss09 no elecrical power
I had the same problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Posted on Jun 03, 2009
heatman101
  • 43501 Answers
SOURCE: KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
Hi is there avfuse box or fuses on the stove?
If its an electric stove the fuse panel should be in the upper back of the stove. Ours was in the top behind the clock. There should be a fuse for each burner and one for the oven.
Jul 19, 2015 | Ovens
The burners on my Maytag electric stove work intermittently. Advanced cooking system Super capacity model.
If intermittenly you mean they quit glowing at times is how mine work also and wife does not say they don't cook alright but they do turn off and on as heat requirement changes
Jan 11, 2015 | Maytag Gemini 30" Self-Cleaning...
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
Whirlpool accuwave oven & hood totally quit
I don't know about the fuse on the stove but check and see if its still plugged in and make sure that the wiring is sound and then go to the breaker box and see if the breaker is tripped. And Most electric appliances have a safety fuse somewhere.
Oct 02, 2012 | Microwave Ovens
Lower Oven Element
Are there fuses in this stove. There usually are in most electric stoves Quite often in the back behind the clock if there is one..
You may have blown a fuse.
Oct 18, 2017 | Frigidaire GLEB30S9F Electric Single Oven
The stove top works fine .Both of the ovens stopped working and there is no digital display where the clock is . Where is the fuse located for the ovens
Normally, there is a master switch on the wall near the oven. This is in turn is usually fed from its own fuse/breaker on the consumer unit. I suspect this has bblown.
Jul 18, 2011 | Stoves 720EF Electric Double Oven
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
All stove top elements and oven wont work
Go to your home circuit/fuse panel and reset the fuse or circuit breaker for the range.
Dec 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Oven elements dont work / stove top works fine
I just had a repairman fix my Kitchenaid 507KERCYAL0 electric range and oven. The problem was a $4.00 fuse. I didn't see exactly what he did but he accessed the fuse from the rear - had to pull out the range and I think remove a panel. Hopefully this helps and saves you $$. I ended up paying $90 to fix a $4 problem
Nov 28, 2007 | KitchenAid KERC507 Electric Kitchen Range
Kitchen Ranges Logo
514 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
