Question about Brother MFC-845CW multi-function All-In-One InkJet Printer
My Brother MFC845 All-in-one. although I do hear it start-up to clean it self reguly but on test print output it is getting worse the more times I start option cleaning the worse missing dots I get red is OK Cyan only 20% clear black is 50/5- but yellow ZERO ¬!. All new Ink cartriges fitted. very little info about taking printer head out to soak in ISOPROPLENE. I have heard people do. Thanks
Plese send c295 printer informesation
Posted on Sep 16, 2010
My brother mfc j220 canoot print magenta color although on the display the magenta is full i clean many times but when i test print i didnt see dotted magenta. what can i do?
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 06, 2011 | Brother MFC 210C All-In-One InkJet Printer
When I test print, I do not get a full pattern of black dashes. I changed ink cartridges and have the same result. The color test prints are fine
If you are missing dots it is due to the print head not the cartridge.
Try doing a self cleaning a few times (max of 5) by pressing "ink" and select "cleaning"
If after 5 cleanings there's still a problem, you may need to have the printer serviced or replaced.
Since you're still getting most of your dots though, I think the cleanings should clear it out.
Thanks,
Pat
Mar 31, 2010 | Brother Multi-Function Center MFC-240C...
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
The printer
You may need to clean the printhead: (make sure you have paper in the tray)
1) Press <Menu>
2) Press <Up> or <Down> arrow to select "Ink" then press <OK>
3) Press <Up> or <Down> arrow to select "Test print" then press <OK>
4) Press <Up> or <Down> arrow to select "Print quality" then press <OK>
5) Press the <Color Start> button. The quality test sheet will be printed. Check this printout for gaps in any of the colors or black in the pattern across the page.
6) The display on the printer will ask if the print quality is OK:
- If all lines are clear and visible, select "Yes"
- If gaps appear in the pattern, select "No"
7) If you select "No" the display asks (in turn) if the print quality is OK for black, and the three colors.
Respond "Yes" or "No" accordingly. (In this manner you may clean just the black or color nozzle that is giving you the problem)
8) The display asks if you want to start cleaning - choose "Yes"
9) After cleaning is finished press the <Color Start> button - the print quality sheet will print again.
At this point you may determine that another cleaning cycle is necessary. You may need to repeat cleanings (up to five times) to resolve the problem. Any more than that indicates a problem that may need brother customer support.
10) When the print quality test sheet meets with your approval, you may exit by pressing <Stop/Exit>
Jan 21, 2010 | Brother MFC-290C Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
Black ink will not print (new out of box).
If cleaning doesn't work you should talk to your retailer or Brothers support. Don't think they can expect you to use up all ink cleaning cartridges when the machine is straight out of the box..
Jun 01, 2009 | Brother MFC 6490CW InkJet Printer
MFC-7420 GHOST IMAGES
sounds like a bad drumbur also can be caused by a defective fuser.
Jan 16, 2009 | HP LaserJet 1020 Printer
Self cleaning and print test sheet
To print a test page, from ready press the go button. There isn't a cleaning page or drum cleaning cycle on Brother printers.
Brothers are notorious for having bad toner and drum issues. They are very finicky about paper quality. What happens is when a lower quality paper is used the higher paper dust and talc gets caught up in the charging brushes of the drum. Brother has no waste sections in their cartridges or drums so the built up junk stays right in the charging brushes and causes the drums to fail. On the toner cartridge side it re-uses it's waste toner adding it back (with the paper dust and talc) into the fresh toner supply area. Eventually the cartridge contaminates itself to the point of causing imaging problems.
Best recommendation after over 13 years fixing printers to you is to use GOOD paper at all times with Brother printers. Brands tend to fluctuate wildly in quality but the most stable brand to look for is a HP (Hewlett Packard) brand paper. They tend to keep the tightest control over paper with their name on it than others I've seen. HP "Office" paper is relatively inexpensive and will save you much more in the long run than buying cheap paper. STAY AWAY FROM STORE BRAND PAPERS OR XEROX 4200.
Hope that helps you.
Aug 11, 2008 | Brother HL 5250DN Laser Printer
DCP 117C Brother ink jet printer: Although ink cartridge is filled, is showing black nearly empty error message. No black is getting through on test printing after head cleaning procedure.
two diffrent errors:
1. near empty. I guess your cart is at full level.: Take cart out. unplug dcp from power. leave scanner open. replug to power. machine will come up and demanding cart. insert cart. close cover. answer display if its changed!
2. press menu then start bk-copy then four times arrow up. machine will be in maintenance mode. press by help of arrow-up and set: 7 (set) 6 (set) 3 (set) start bk-copy. machine will do a power purge cleaning. when finished press 9 (set) 9 to leave maintenance mode. run a test print and set date/time again!
Apr 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-845CW multi-function All-In-One InkJet Printer Logo
100 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
