Question about Hotpoint Ultima WF860 Front Load Washer
Washing machine fault code 08 coming up
My front loader washing machine being a whirlpool WFS1273AW comes up F:08 fault after i drain it.
Posted on Nov 29, 2008
  • 1,224 Answers
Cloged hoses or pump
kinked drain hose
Posted on May 30, 2008
3 Suggested Answers
  • 3463 Answers
SOURCE: fault codes for indesit washing machine, the display shows F-08
F08 means that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
The only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Plz rate my solution.
Posted on Jan 24, 2009
  • 3463 Answers
SOURCE: hot point f-08 fault code
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Posted on May 20, 2009
Hotpoint Ultima WT721 F 08 fault code
Try the brushes first. I'm guessing the carbon deposits on the floor are from the brushes.
Nov 16, 2013 | Washing Machines
I have a hotpoint WT940 error code f-08 has appeared, what does this mean
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
Oct 14, 2012 | Washing Machines
Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 23, 2010 | Hotpoint Ultima WF865 Front Load Washer
Ariston AIB16 flashing fault code f-08? can this
F08 Heater relay cannot be activated
this can be repaired cheap its part of the main board
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Ariston Technologies Washing Machines
My hotpoint washing machine wt960 keeps displaying the fault code f-08 when trying to do a 40 c wash
Error code F08 is indicating that the heater relay cannot be activated.
Check all connections on pressure switch----module---- and heater.element.
Hope this helps, this is the recommended procedure.
Dec 01, 2009 | Washing Machines
Error code F-08
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think you will find the pump comes on because the heater relay is stuck which then gives out the error F08, not the other way round. Check the heater, the pressure switch and the module connections (you will need a multi meter of some description) to check the connections.
Jul 09, 2009 | Washing Machines
Showing error code F-08
We let the washer stand for 45 mins then tried to wash again and it washed another 3 times and has not shown the fault since.It is the relay for controlling the heating element and tends to stick when it gets warm.We found that letting it cool for a while and resetting itself it worked again.This might not solve the problem in the long term but it worked for now.The fault shown was F-08
Thank you
Jun 16, 2009 | Hotpoint Ultima WD72 Front Load...
My Electrolux Washing machine has fault code here and type in the model in the search bar and download the manual for the machine this will help
Jun 11, 2009 | Electrolux Washing Machines
Hot point f-08 fault code
May 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Indesit 1300 evolution washing machine
my machine light comes on but it will not start
Feb 12, 2008 | Dishwashers
Hotpoint Ultima WF860 Front Load Washer Logo
545 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
