Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
I own a KUDS01FLSS3 KitchenAid and the bottoms on top have worn through. What is the panel number for the panel?
    Champion:
  • 246 Answers
I'm not sure what panels you are looking for. I know Appliance Art sells custom stainless panels for the dishwashers that allow you to slide out old panel and insert new one. They also have stainless steel "rolls" for wrap-around dishwashers. www.applianceart.com
Posted on Feb 02, 2011
Our KitchenAid dishwasher started making scary baby cry sounds. then a few months later the clean dishes would have a white film over them like dried detergent didn't rinse.
Hello Cindy;
My name is peter. I am a retired field service appliance technician.
You need to provide a model number so I can see what you have. The model number is on a tag on the front face of your dishwasher after you open the dishwasher door.
You may want to remove the bottom front panel on your dishwasher, run the dishwasher and observe. There are two clip pins on the top of the bottom panel. Push in with a putty knife or something similar. Pull on the top of the panel on both sides, then lift the panel up.
Jun 08, 2015 | KitchenAid Dishwashers
Kitchenaid mixer will not start
The model number shown is for the Professional series which does not have a separate rear cover. Below are links to KitchenAid mixer Service Manuals:
Professional 5/6 quart
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
4.5/5 quart
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 13, 2014 | KitchenAid KP26M1X Stand Mixer
KITCHENAID LOCK IS GETTING STUCK AND MIXER IS CLUNKING
I am having the same problem. The head wiggles when beating and the blade is getting worn on the bottom, protective cover is getting worn off by hitting bottom of bowl. I have to wiggle the head in order for the head to lock in place. thanks for any help - Diana
Jan 11, 2014 | KitchenAid K45SS Classic Stand Mixer
What are the dimensions?
You are missing a digit in the model number. KitchenAid Dishwashers have a number (0-6) after the SS.
The KUDI01FLSS0 installation guide gives the dimensions of the dishwasher opening and the unit itself on various pages. See http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208524480.pdf . The top vent and the front vent KUDI01FLSS model washers are slightly different. The front vent dishwasher dimensions are 33 7/8" H (with the wheels removed) x 23 7/8" W x 24 7/8" D (including the handle). The top vent model is only 24 1/2" deep. With the wheels in their lowest position, the opening for the dishwasher must be 34 1/2" high (from floor to the bottom of the counter top).
I hope this helps. Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Use the search box to enter the model number and use the drop down menu to select Consumer.
Aug 14, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Motor not turning on
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Make sure that the Motor Brushes are not worn out and making good contact with the Motor.
Adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 15, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I own a KUDS01FLSS3 KitchenAid dishwasher. The lights on the control panel do not come on and a cycle can not be started. There is about an inch of water in the bottom of the dishwasher basin and it looks...
The problem with the unit is the thermal cut-out/fuse has tripped. You'll need to purchase the replacement kit #959376. It should be available at most local parts retailers, or online parts depots as well. (double check with your model number, but that is the most common)
**Be sure to use the entire kit**.
You'll notice there are new wires to the fuse to be spliced into existing ones, this is to ideally prevent the problem from re-occuring. (follow the instructions provided, you'll be fine)
If the problem does re-occure in the near future, you'll need the control, #1060952
hope that helps,
Good Luck
Oct 18, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid refrigerator side by side, refrigerator door will not close on its on like it use to. Model #KSRS25qDWH01 bought in 1996. If we give it a push it closes fine. But it use to close nearly b
order a cam and stop for the affected door. it is on the top of the hinge and the bottom of the door, you'll see the two pieces if you look where the door contacts the hinge, call a dealer for the correct part numbers.
May 04, 2009 | KitchenAid KSCS25FKSS Side by Side...
Model Number
Open the drawer or bottom cover panel and look on the facing where the door closes to
Dec 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
156 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
