Question about Linksys SPA9000
SPA9000 latest firmware (6.1.5) After Factory
SPA9000 latest firmware (6.1.5) After Factory reset Test setup... SIP -> PBX PAarams Dial Plan () FXS1 Extn 391 same test dial plan FXS2 Extn 309 same test dial plan Dialing 2 on FXS2 causes FXS1 to ring instead of getting to aa change FXS2 to EXTN 392 Dialing 2 gets to aa Am I going crazy?
What are reasonable prices for SIP trunking?
A cheap SIP trunk service is the great solution for a company which is in the process of converting traditional telephone service to VoIP system. However, if the company has PBX system, then it is not necessary to replace all equipment and you can use SIP Trunking which is less expensive. SIP Trunking allows your existing PBX system to Internet for VoIP connection. In SIP, bandwidth matters a lot to get proper network throughout the use. Also, features like:
1) Efficiency of data connectivity
2) Sharing of international voice calling across enterprise
However, the price of SIP Trunking also matters. The price of the service depends on the plan you're taking. Different companies have different plans having features along. Reliance Global Call is a prominent company offering SIP Trunking solutions. The enterprise SIP Trunk allows you to have international long distance calls under cheapest price.
May 16, 2017 | Computers & Internet
Why Add SIP Trunking to Telephone System?
SIP trunking is cost effective, particularly when you are doing international calls, relative to general telephone technology. Enterprise Sip Trunk is Voice over Internet Protocol (VoIP) and streaming of media service is based on Session Initiation Protocol. By unifying these protocols Internet Telephony Service Providers (ITSP) deliver their services to those customers who are equipped with IP-PBX and facilities having unified communications. IP-PBX is SIP based private branch exchange. You can seamlessly stream voice, video, conferencing, etc. on this platform.
There are two domains of SIP trunking- private domain, public domain. Private domain is typically owned by a person or a firm through its server equipped with IP-PBX. Whereas public domains use PSTN. In private domain, the responsibility for everything is that of the firm or the individual, but in public the responsibility is that of the Internet service provider.
May 02, 2017 | Radio Communications
How do i assign numbers to flex buttons
I have a similar phone, the IP8830. Press the button to the left of the round button (looks like a cog) . This is the configuration menu key. Press 1 then 2 and get your IP. Once you have your IP, enter it in your web browser so it looks like this (http://192.168.1.200:8000) . The default user name on mine is "private" and the default password is "lip" . Once you are logged in you can go to "Phone Settings" and set the number of lines on the keys. Next you can go to "Programmable Keys" to set your BLF and Speed Dial Keys. I am using SIP firmware with a Asterisk PBX so yours may be different. My firmware version is "1.1.04spbx_a" .
Nov 06, 2014 | LG Ericsson LIP-8012D 12 Button IP Phone
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Apr 16, 2014 | Samsung Computers & Internet
Phone looks fine but there are lines through the connection. I dial and get busy signal. Check all connections, everything seems fine, reset the phone a bunch of times, still not connected though.
If there are lines through your line appearances than your phone is likely not properly registered with your Callmanager or SIP registrar, you need to configure your phone properly so it registers and associates with an extension on your PBX or hosted service.
<a href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
Sep 24, 2012 | Cisco 7940 IP Phone
Does the system has music on hold and sip trunk
I guess you're new to this. The phone may have music on hold, it depends on the model but is generally something you have when using a pbx.
No phone has a sip trunk, that is what you connect to with your voip provider. You need to setup a sip account with a voip supplier and program your phone with the settings provided by them.
Apr 03, 2011 | Computers & Internet
How to fix that computer does not recognize router?
Try to reset the router to factory defaults.
To reset your router to factory defaults, use the following procedure:
1) Power down all computers, the router, and the modem, and unplug them from the wall.
2) Disconnect all wires from the router.
3) Power up the router and allow it to fully boot (1-2 minutes).
4) Press and hold the reset button for 30 seconds, then release it, then let the router reset and reboot (2-3 minutes).
5) Power down the router.
6) Connect one computer by wire to port 1 on the router (NOT to the internet port).
7) Power up the router and allow it to fully boot (1-2 minutes).
8) Power up the computer (if the computer has a wireless card, make sure it is off).
9) Try to ping the router. To do this, click the "Start" button > All Programs > Accessories > Command Prompt. A black DOS box will appear. Enter the following: "ping 192.168.1.1" (no quotes), and hit the Enter key. You will see 3 or 4 lines that start either with "Reply from ... " or "Request timed out." If you see "Reply from ...", your computer has found your router.
10) Open your browser and point it to 192.168.1.1. This will take you to your router's login page. Leave the user name blank, and in the password field, enter "admin" (with no quotes). This will take you to your router setup page. Note the version number of your firmware (usually listed near upper right corner of screen). Exit your browser.
If you get this far without problems, try the setup disk (or setup the router manually, if you prefer), and see if you can get your router setup and working.
If you cannot get "Reply from ..." in step 9 above, your router is dead.
If you get a reply in step 9, but cannot complete step 10, then either your router is dead or the firmware is corrupt. In this case, use the Linksys tftp.exe program to try to reload your router with the latest firmware. After reloading the firmware, repeat the above procedure starting with step 1.
If you need additional help, please state your ISP, the make and model of your modem, your router's firmware version, and the results of steps 9 and 10. Also, if you get any error messages, copy them exactly and report back.
Don't forget to vote thanks!!
Oct 29, 2010 | NetGear WGR614 Wireless Router
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
Audiocodes MP118 8 FXO early media to Freeswitch SIP extension
Hi, man.
There are many things to consider in this type of application.
when calling from PSTN to IP using analog lines from time to time you will have this type of event, I suggest working with H323 protocol, this will tone down a bit your problem.
If you want optimum performance, you should use a DID with the channels you need and address to your PBX SIP FreeSwitch. The DIDs are cheaper and are digital which eliminates random connectivity problems in the incoming call.
Once you have directed the DID you tell your server to transfer the call to the IVR using your internal dialing plan.
Lucky
Oct 06, 2008 | AudioCodes MP118 Analog Modem
Linksys SPA9000 Logo
220 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
