Electrolux Model Aquashower 500. The washing program cycle completes very fast. Even before full water intake, it drains and moves to the next program. Some clothes are not even wet when the cycle ends. Problem just started after 7 years usage.
aborcass
  • 2651 Answers
SOURCE: washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Posted on Apr 29, 2008
SOURCE: does not spin fast enought to get rid of water
mY ROPER WASHING MACHINE WILL NOT SPIN OR RELEASE WATER
Posted on May 05, 2008
Krazytech
  • 725 Answers
SOURCE: clothes are too wet at the end of the washing cycle
washer is not spinning out ..
first check your drain pump there is a coin trap .Under the front panel. remove the three screws and you can clean it out
Posted on Nov 17, 2008
  • 36 Answers
SOURCE: clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Posted on Dec 17, 2008
  • 21 Answers
SOURCE: wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Posted on Dec 29, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
My top load electrolux washer machine, model MEX731CAS3 does not drain. it spins well and the cycle gets completed except the draining and centrifuging part. any suggestion?
The function of the pressure switch in the machine that gives a signal if the washing machine is full or empty with water.Spining cycle will start only if the machine is previously drain water and pressure switch overlapped to the empty position. Check everything about pressure switch and hydraulic circuit (tube and pressure chamber).
Dado
Jun 25, 2015 | Electrolux Washing Machines
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Spin cycle does not work properly
If clothes are still wet this mean there is still water in the drum and the pressure switch is not switch in empty position. The fault should be sought in the draining phase. Could be: drain pump ....
Dado
Kitchenaid washer model kawe742wwh1; when it gets to wash cycle will stop completely.
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect. If the machine stops at the wash cycle after the pressure sensor works then it can be the control panel board as the processor or drive is faulty and so there is no output to the motor.
If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 04, 2012 | Whirlpool Washing Machines
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer LSQ8543JQO -- in cycle issue
what brand washer? if lidswitch is bad most washers will not drain and spin to move to the next cycle
Nov 19, 2007 | Washing Machines
Intermittent wash cycle
If there is a filter on this model, make sure it is clean, a lot of fluff and other stuff can accumulate in the filter preventing the water from draining fast enough. Sometimes the pump can get blocked with the same effect. Tom.
Feb 26, 2007 | Haier XQG50-QF80 Front Load Washer
Washing Machines Logo
524 people viewed this question
Top Washing Machines Experts
