I have an older model of Sony receiver STR-V333ES. I didn't use it for couple of years and now after i tried to pair it with my Sony super audio CD player I am getting a message on the front pannel "PROTECTOR PLEASE POWER OFF". I can't get any sound from the speakers, so it sound like power output issue? I couldn't find anything in the manual dealing with above mentioned message. It is something with the menu set up or amplifier problem? Tom
  • 4,472 Answers
This is an amplifier problem. Most likely an internal component has failed, it displays this message so no further damage is done. I would recommend finding a local audio electronic repair professional and get an estimate on repair. Just keep in mind you can find a comparable/upgraded receiver from sony for about 200-300$. So don't spend to much on repair, as you could still sell yours for parts/repair.
Thank you,
Lee
Posted on Sep 16, 2010
Sony STR-DG910 is in protect mode how do i solve this?
Most likely it needs repair of one of the output channels. Pair of transistors and a couple of resistors probably.
Jan 31, 2011 | Sony STR-DG910
PROTECT shows every time I turn my reciever on. It's a SONY model #STR-DE335
Turn it OFF. Look for shorted speaker wires or shorted speakers.
None found? Disconnect all speaker wires and try to turn it on.
Turns on ok? One of the speakers/cable pairs is shorted. Check them again.
No good? It's dead. take it to a tech.
http://www.retrevo.com/support/Sony-STR-DE335-Receivers-manual/id/387bh942/t/2/
Jan 08, 2011 | Sony STR-DE335 Receiver
Second Sony DE135 overheating. One has completly failed and other goes to Protect mode. Trying to connect 2 pairs of new ceiling speakers (8ohms) each through its own JA Audio Impedance Volume Control. ...
I"m not trying to be the expert on this but i had the same problem with a older sony and it ended up be a short in the wires in the wall. You can test it with a volt meter.
Dec 26, 2010 | Sony STR-DE135 Receiver
Remote's will not work with my Sony STR DE-485
the ir feed receiver amplifier has failed a common sony fault on older units a fix is about $100.00 or use a repeater ir blaster from circuit city for $40 and try that you can return if no success the repeater eye covers the receivers originaland pumps up the out put into the unit
Sep 09, 2009 | Sony STR-DE485 Receiver
See add details
Since the receiver eventually works, the delay circuit is failing. This is a circuit that allows the power supply to settle down before kicking in the output relay. This prevents the "pop" that was sometimes heard on older units. This should be a simple and inexpensive repair probably requiring the replacement of a couple of small capacitors in that delay/protection circuit.
Dan
Mar 09, 2009 | Sony STR-DE935
My sony v333es say protection panel power off
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 03, 2008 | Sony STR-V333ES 5.1 Channels Receiver
Sony STR-V333ES repeatedly clicks when i try to power it up. is there an internal fuse???
You most likely have a short in one of your speaker wires (+ and - are touching somewhere) causing the receiver to enter a protect mode "Click!". Disconnect all speaker wires then connect and test each one at a time to find the culprit. I've seen this happen with speaker wire or a subwoofer cable that is too small of a gauge. Hope that helps.
Feb 19, 2008 | Sony STR-V333ES 5.1 Channels Receiver
Bose AM-500 Acoustimass Bass module hookup to new Sony STR-DG910 Receiver
it need it own sub out speaicl done so bye bose steyem crossovers wont work right in your set up nee dto upgrade the sub try mtx
Feb 04, 2008 | Audio Players & Recorders
37 people viewed this question
 Grubhead
Grubhead
