Question about Rockford Fosgate P3001 Car Audio Amplifier
Is it a chance that my battery will drain with the amp still on after the car is not running??
    Habit-Forming:
  • 106 Answers
The amp will drain your battery eventually if it remains powered.
Posted on Sep 16, 2010
The IOD is pulling 2 amps n draining battery over night. What can I do to correct the problem???
Testing for Battery Drain - Randy's Repair Shop
randysrepairshop.net/testing-for-battery-drain.html
Instructions for measuring automotive battery current drain. ... Excessive current drainwill usually result in the battery running down overnight or within a few days. ... Many digital meters have a 2 amp internal fuse that may blow if multiple ... If pulling fuses and circuit breakers doesn't stop the current draw, you'll need to look ...
How do you trace a drain on the battery of your car with an ...
www.instructables.com/.../How-do-you-trace-a-drain-on-the...
InstructablesApr 13, 2011 - I know this is an old question, but I that if the battery cable is not clean or .... I wish I could find one of those 14.4 Vdc 2 Amp solar chargers. ... be to pull a different fuse every night (not the ones which would require factory help ... As others have pointed out, the LED will not drain a good car battery overnight.
Diagnosing A Car Battery That Runs Down
www.aa1car.com/library/battery_runs_down.htm
Jan 05, 2016 | Cars & Trucks
My battery keeps getting drained when my car is not running. auto place said that I have a drain when my car is not running and that my battery andalternator test good. What might be draining my batte
The only way to solve this problem is to isolate which circuit is causing the problem. To do this you must have an amp meter. (one that will read up to 10 amps minimum; I doubt you are drawing more than that) With key off, disconnect the positive cable to the battery and insert amp meter, positive meter cable to positive terminal and negative meter cable to positive cable on car. Normal draw will be in the milliamps. Anything 1/4 amp or more I would consider abnormal. Then star removing fuses (one at a time) until drain disappears.
Aug 28, 2014 | Cars & Trucks
Battery on 98 Ford Expedition doesn't hold charge
First thing I would do is have someone qualified disconnect the alarm and stereo and start over.
Chances are you have circuits cross-connected and something is draining the battery.
Jan 14, 2013 | 1998 Ford Expedition
New battry keeps running down
If your battery runs down when the car is off and not running, then you probably have a 12volt drain
killiongthe battery. If your problem occurs even when the car is being driven and used, then your alternator may be the culprit, it may not be charging enough. Attach a voltmeter across the + and - battery terminals. Start the car and let it idle without any accessories on. If you get a reading somewhere between 13.75 - 14.75 volts, your alternator is ok.
To check for a 12volt drain, disconnect the negative battery terminal and slowly scrape it on
the negative battery post 3-4 times. If you see any light to medium sparking as you do that, you probably have a 12volt drain killing the battery. BTW, don't be afraid of being shocked, no chance of that. This is extremely light voltage we're taking about here. Any 12volt drain is best left to a professional to trace down. Oh yes, a defective new battery is possiblity, but highly unlikely.
Sep 28, 2011 | 1998 Chrysler Sebring
1989 chevrolet caprice alternator draining battery, and wont start. We replaced the alternator, feul pump, battery, & starter.
There is a circuit staying open that is draining the battery. Chances are it is the ignition switch or the starter relay. Most likely it's the ignition switch. If it stays open the starter circuit continues to draw power even though the car is off. It's under the dashboard above the gas pedal. Someone should be able to test it with a circuit tester to see if it's the problem. Good luck!
Nov 20, 2010 | 1989 Chevrolet Caprice
Okay about my car radio... when i turn my
there's a good chance that your car battery is getting old. Car batts are good for about 3 years and then they'll work but can drain the battery with accessories left on when the car is not running to recharge the battery.
Have the battery checked... it may be time for a new one.
Sep 12, 2009 | Car Audio & Video
Battery Drain when parked.
First off, how old is the battery? It is possible it might be stratified and its just no longer holding a charge well. I've had batteries that are 2 or 3 years old and then they just go dead if I don't start them up every day or so. (Some batteries are just made better than others) If the battery is brand new, then check for some possible wiring shorts. Try looking at the engine running in the dark and try moving around the wiring harness to see if by chance you see any sparks or arcs of electricity. Other than that, you might have to have a qualified auto electric mechanic to check it out for any abnormal power drains.
Jul 30, 2009 | 1995 Dodge Ram 3500
BATTERY DIES OUT IN 2-3 DAYS.
are you saying that you got this battery from autozone? I went thru three batteries in a week from autozone because the lot# was bad. It,'s quite possible that you have either a short that is draining the battery or that the alternator isnt charging properly. To do a fast check, start the car then remove the positive battery cable with the car running. If it stays running, theres a chance its ok. If it dies, It's most likely the alternator or the voltage regulator Diods. On most cars, the voltage regulator is built into the alternator. I would take it to autozone and have the charging system checked
Jun 03, 2009 | 2006 Pontiac G6
2001 boxter s ,can not keep the battery charge
replace or renew ??chances are that if secondhand you have someone elses problem.how long does it take to run battery down?? have you disconnected battery and put an amp meter between cable and battery terminal to measure discharge ,does battery still go flat when disconnected .do you have a big amplifier in the boot .chances are you have answered your own question.work with elimination as the one thing that can cause a battery to discharge is a diode in the alternator.next is a radio /interior light or boot light ,amplifer in boot for the sound ,,now if the battery goes flat disconnected then renw the battery .or drain the acid out then flush it out with a hose ,swill with distilled water then refill with acid ,sounds drastic but it often works as a bit of paste can short a plate across.have a play because thats all a mechanic would do.And as for a dealer chances are that if you changed these parts yourself then they would not be very coperative to say the least .
Nov 15, 2008 | 2001 Porsche Boxster
Rockford Fosgate P3001 Car Audio Amplifier Logo
57 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
