Question about Laguna PressureFlo UVC Filter PF 1400 ()
I have a Laguna Pressure Flo 3200 and it is not working. I purchased a replacement UV lamp and the lamp is not lighting. Is there a fuse in the pressure flo component?
3 Suggested Answers
  • 56 Answers
SOURCE: My Laguna pressure flo 2100
Have you tried turning the impeller gently by hand? Sometimes this gets jammed.
If it is running but water still isn't flowing you may have an air leak. You can locate one of these by running a hose along the seams and waiting for the pump to prime.
If the impeller turns easily but still will not spin when power is supplied your motor may be dead. If you feel a vibration or noise when powered up and the impeller still will not spin the magnet on the impeller shaft may have detached from the impeller drive.
Except for the motor all are easy fixes with inexpensive parts that should just drop in.
Posted on Mar 13, 2011
  • 794 Answers
SOURCE: The cleaning handle(S) on our
Hi genejo4boys,
Cleaning handles for this are replaceable. You may contact this number 800-352-4769. They do sell genuine Laguna Filter Replacement Parts. From Filter Foam, to O-Rings and UVC Replacement lamps to Service Kits and of course cleaning handles. You may want to check out with them.
Hope this helps.
Thank you for using FixYa.
Posted on Jul 25, 2011
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
Laguna PF 3200 By ASKOLL
sorry I meant powertrain cradle
Jul 10, 2013 | Cars & Trucks
2 tanning bulbsdont work. could it be the fuse in the bed
maybe they burnt out. you can use an UV reader, which lets you know when to replace the bulbs. it tells you how much UV light is being outputted. When you replace your tanning lamps, it is ideal to replace them all at once.
look here for more info http://www.mastertanning.com/tips/23/tanning-lamps/
Feb 26, 2013 | Health & Beauty
Do you carry uv-c t5 11w if so how much
It cost 12 dollars at the link below...
http://www.lightbulbsurplus.com/index.php?main_page=product_info&cPath=622_128_133&products_id=256
Mar 21, 2011 | Laguna Pressure Flo Uvc Filter 11w...
New uva light not working, have been told about a reset button but unable to find it
On the bottom of the UV head where you just replaced the bulb. There are 3 screw holes and a 4th hole with the button in it.
May 10, 2010 | Laguna Pressure Flo Uvc Filter 11w...
2002 renault laguna petrol,number plate lamps not working.have replaced bulbs and removed and checked all fuses
it not a problem with fuse you have to check wiring contuenity, from no light to fuse box, it may be disconnected .
Jan 21, 2010 | 2006 Renault Le Car
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Laguna PressureFlo UVC Filter PF 1400 () Logo
42 people viewed this question
Top Laguna Garden Experts
Dennis Key
Dennis Key
john h
Are you a Laguna Garden Expert? Answer questions, earn points and help others
