Question about Neff Dishwashers
The water is not entering the system but will drain away. All the normal lights are on except for the water.
  • Neff Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 18, 2010
How do I fix a washing machine that doesn't fill with water, but spins and drains? Water enters the detergent holder, but doesn't seem to make it to the tub. Draining can be heard as well, even though
Hum for one a front load H.E washer should not be having very much suds as u claim it had. Are u aware the front loads are made to use very little soap and if u use to much soap hence alot of suds, ur SUDS SENSOR will act up and can shut down any wash cycle. a trick is to run just water and some vinagar trough a couple loads if u can get to wash at all. Another issue u may have is a plugged line somewhere. or loose unconnected water hose line hence the water on the ground effect. u may want to check ur flow line from the entry into the tub where the water at the moment I cant recall the name of the gadget but it can get clogged or damaged and hinder the water from entering the tub
Jan 15, 2015 | Kenmore Washing Machines
Seems like there should be a pump or sending unit the would be controlled by the cycle timer. ProbAbly went bad. Hopefully you got the extended warranty?
Fridge defrosting to often resulting in water build up in back of fridge
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Units are designed to go into a defrost mode every 8-10 hours, where everything will shut down with the exception of your lights. Your defrost heater will turn for 20-30 minutes, and then your unit turns back on.
Normally, water build up is due to a frozen condensate drain, where the drain is frozen and the condensate (Water) has no where to go except for the bottom of your freezer.
If your drain is clear, then you have a major problem, Unplug your unit. Remove the back cover of your freezer. In the upper right hand corner of your freezer coil, you probably have a block of ice. This means that you have a seal system restriction. The is a small tube about 1/16" in diameter with a small needle size hole through it. Here is where restrictions generally occur.
A repair of this nature is about $450.00 or more.
Sorry for the bad news.
Dec 15, 2014 | Whirlpool Refrigerators
Bosch sgs45c02 salt container ful of water
the salt dispenser is always full of water, this is normal and you have no need to drain it. Just ensure you fill the dispenser with salt when the "Low Salt Light" is illuminated
Oct 03, 2012 | Bosch SGS45C02 Dishwasher
I put on a dark wash and the water didn't drain away. How long would this cycle normally take? How do I drain the water away?
gsldgasdghashgasjhsdgshdgakshdgahgashdgasd gsdkga jsgdhsgdasdghsdgadg aksgdskadgaksjdgsakjdgasdgas
Jan 25, 2011 | Washing Machines
Water leaks into the vehicle on the front,
It could be a plain old fashioned leak around the windscreen - difficult to find but try sitting in the car while somebody plays a water hose over the windscreen.
It could also be a blocked drain in the ventilation system - fresh air is normally drawn in to a car via vents at the bottom of the windscreen. These vents normally lead to a "box" like structure where any water that enters the vents drops to the bottom and then drains away via a short hose that runs to somewhere underneath the car.
If the drain outlet or hose gets blocked (by leaves for example), it can cause the box to fill with water to the point where it can leak out in to the passenger area.
Hope this helps you find the problem.
Nov 16, 2009 | 1999 Ford Taurus
Water continues to drain on the spin cycle while filling
there is no actual drain valve, but rather physics to keep water in tub.
The drain system MUST be located HIGHER than the deck fo the machine, with console height being preferred.
Drain during spin cycle is normal, as rinse is intended to also drain away at that time..
Doc
Sep 18, 2009 | Washing Machines
I have a Kenmore upright freezer-model LFFH2067DW2 -the red light has been on for at least 12 hours and the freezer is defrosting-water is leaking on the floor-there is a vent insidethe freezer and the...
I was made aware of your concern and would like to offer a few ideas you may want to consider. Water dripping down is not a leak during defrost condition as this would be the ice melting. Normally, there would be a drain hose specifically to channel the melted ice/water to a drainage system. The amount of water would then be proportional to the amount of ice melting as with the length of time to completely melt, drain away.
Perhaps you could check the filter/drain screen as well as the drain opening for any blockage/clogging. You could also try checking the same on the drain hose as well as for possible kinks. Additionally, there would be a sensor behind a boxy cover that triggers the system back into operation. If there is still melted ice/water inside the freezer, then the sensor would prevent the unit from turning on completely. You may want to check this sensor and verify that it is dry.
An exploded parts diagram would help you identify/locate the above mentioned parts.
Good luck and thank you for using FixYa.
Feb 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The water does not drain away at the beginning of the programme.
you may have something stuck in the pump its hard to say but you should have it checked to see.
Jan 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Dishwashers Logo
88 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
