I have a HP Laser Jet 3800n and it is showing the code 49.4C02 Service Error Code.
  • 1,218 Answers
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem. get more information and help Printer Error 49.4c02
Posted on Sep 18, 2010
How can I repair laser scanner HP m 500/525 mfp?Every time when it shows the error code,I try to calibrate the scanner and shows black vertical lines.
this is very difficult to solve from your location. I will give you tech support ,please send me your email address or add me your skype xptareq2000@msn.com
Aug 20, 2016 | HP LaserJet Enterprise 500 M525f MFP -...
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
Hp color laser jet 5550dn shows error code 10.10.02 supply memory error
This error codes indicates that one of the toner cartridges you have installed does not contain a valid chip on it. If you recently changed a cartridge that is the likely culprit.
Feb 28, 2015 | HP Color LaserJet 5550dn Q3715A Workgroup...
I have an error code 58.04 on my hp color laser jet pro 300 M351a can you help me out to reslove this error
Lots of suggestions from the HP site: http://h30499.www3.hp.com/t5/Multifunction-and-All-in-One/HP-Color-LaserJet-CM6040-MFP-58-04-Error-message-error-code-not/td-p/4821025#.VVCSS5I4nTY
Jan 28, 2014 | Office Equipment & Supplies
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
The printout is low quality not smooth ?
Generally with all laser printers the print quality is low when compared to that of a inkjet printer. Try cleaning the Printer Cartridge and u can make good quality print outs by changing the settings at the time of printing. Use your Laser Jet printer software from HP and clean the device.
Oct 21, 2009 | HP LaserJet 3800n Printer
Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Nov 27, 2008 | HP LaserJet P3005 Printer
2,372 people viewed this question
jasbo
jasbo
