Question about Brother Office Equipment & Supplies
Fax machine continues to say paper jam. We have cleared all areas of paper, removed drum and there is no paper to be seen. Help
    President:
  • 1,194 Answers
I am not sure which model you are using, Makes sure you clear any kind of paper jam sometimes small or tiny piece of paper inside the unit can cause jam.
There's could be possibility that you get false paper jam error when there is no jam in the unit, this is usually caused due to dirt or dust got collected into paper feed section like clutches, feed & pick up tires or dirty sensor, If these component are dirty device will give jam error, Cleaning paper feed section ( Clutch/gears, feed & pick up tires & sensor) with mild soap & water will do the trick.
I hope this will solve the problem
Thanks..!!
Posted on Sep 16, 2010
Its always saying that BACK COVER IS OPEN we already check it for many times but its intact and in correct possition. and also the paper wont feed the machine.
Hi there!!
The message that you're getting means that either the back cover is not closed securely or there's a jammed paper inside. Here's what you can do to clear the message:
-Please unplug the fax machine for your safety -Open the front cover -Remove the toner & drum assembly (theres a handle in the center of the drum/toner assembly, just pull it towards you. -Remove any pieces of paper stuck or the jammed paper -Remove the toner from the drum and check for any other pieces of paper stuck -Once everything is clear -Reinstall the toner back into the drum and the drum & toner assembly to the fax machine. You should hear it click into place once installed correctly -Close the front cover & plug in the power cord. That should clear the message
Hope this helps, Thumbs up if it does, thanks!
May 08, 2011 | Brother IntelliFax-2820 Laser Fax
It says 'paper jam' and won't print, but I have cleared the jam. Intellfax4100
Remove the drum unit and then remove the toner from the drum unit and look for a piece of paper under the toner you just removed, look in the drum area to see a small cut out that the sensor flag pokes through. also throughly check the back door of the machine and look into the fuser area to check for paper there.
Dec 14, 2009 | Brother IntelliFAX 4100 Laser Fax
Error message says unable to print on Brother 2820. It will not answer an incoming call but will transmit a fax. Machine is in almost new condition, barely used.
when you send a fax do you get transmission report? open back to see if there might be a jam, remove cassette to see if there is a jam. if these areas are clear of paper then you have a mechanical problem and it would have to be seen by a tech
Nov 14, 2009 | Brother IntelliFax-2820 Laser Fax
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Paper jam on Pitney Bowes 9910
try a new toner, if not it could be fuser
Feb 17, 2009 | Pitney Bowes 9920 Plain Paper Fax
Brother mfc8220 jam problem
We looked everywhere for a piece of paper stuck in the machine and couldn't find it. We finally fixed the problem by moving the paper size adjuster in the paper try until it was right up against the paper. If the paper is free to move around in the tray, apparently the machine sees that as a paper jam.
Feb 03, 2009 | Brother MFC-8220 Fax
Brother Intellifax 2820 JAMMED
just clean paper path and clean all roolers and specially paper pick up roller.by mian jee
Dec 15, 2008 | Brother IntelliFax-2820 Laser Fax
SF-341P
Remove all papers from the machine, unplug it from the mains suply and try all over again,
If the problem persist most probably there is a broken or an unplug actuator sensor inside the machine or in the scaner area.
GOOD LUCK.
Oct 31, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Faxing
Hi:
You may have removed the paper but the reason why it is still saying paper jam can be caused by at least two things.
If you removed the paper, but it tore while you were taking it out then a small piece could be blocking a sensor or a sensor flag ( a spring loaded finger that the paper has to activate as it moves through the machine) It's possible that a small piece of paper could be blocking a sensor or you may have disloged one of these 'flags' in the area where you first removed the paper. Go back and look closely in that area for a piece of paper or a sticking ''flag'. Until you do that the fax keeps thinking that there is something in the paper path and will keep displaying that message.
Andrew
Jul 20, 2008 | Brother FAX-575 Plain Paper Thermal
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
