Question about Dometic Rooftop RV Air Conditioner
After shutting off the thermostate switch, the unit sounds like it is running down before it stops?
  • wildapowers Sep 16, 2010
    I have had this unit for over a year and this is first time it has happened. It still blows cold air until it shuts down. Could be low on freon and is building pressue up in the compressor? My home unit has "ramp up and ramp down cycles". This problem is not the same because the fan does not seem to be running a the correct speed after the thermostate is turned to the off position. Could the thermostate be defective?
    President:
  • 1,796 Answers
I would say it is normal operation. Maybe you just didn't notice before because it was more quiet. That has nothing to do with the R-22 Refrigerant pressure or thermostat functionality.
Good Day!! Thank you for using FixYa!!
Posted on Sep 17, 2010
  • 3,083 Answers
Has it always done this, or have you just noticed it? I've only worked on house units, but after turning the A/C off, they have a wind-down period where the fan still operates for a few minutes before shutting off.
Here is an excerpt from hubpages.com:
when I turn off my ac the compressor keeps running, I turned it in fan only and it still blew cold untill it froze up. the only way I could git the compressor to go off was to throw the breaker
Randy Godwin 2 weeks ago
This appears to be a switch problem, Tom! Depending on the make and model of your RV AC, the switch may be shorted out and is allowing the elec current to be supplied to the compressor at all times.
The inability to shut off power to the compressor using the off setting on the switch is an indication of a shorted switch! If you are familiar with using a multimeter you can check the switch before buying a new one! Order one online to save a bundle of money!
This might be normal, contact the dealer or manufacturer to find out. Google the brand and word support to find the support site.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 16, 2010
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
Cooling fans run nonstop
Check water temp sensors and fan relays for correct operation. It is not a big problem if the engine is running but it will flatten the battery if the engine is shut down for a period of time.
Feb 23, 2013 | Cars & Trucks
I cannot get my heater to shut off when it get to hot in the house , i have it on 60 and auto and still running. I have to turn it off.
sounds like maybe you have a wire touching somewhere in the thermostat or the thermostat itself is failing, are you turning the power off to unit or turning the thermostat to off .... if you are turning power off then try this frirst turn you thermostat down as low as it will go a wait 1 minute 30seconds to see if it goes off if not then (at thermostat) remove the wire hooked to "w" terminal which if done correctly should be a white wire ... wait a few minutes and see if the unit shuts down ..if it does not see if you are still blowing hot air as the fan may just be running...if the heat portion stops ,but you still have fan then remove the "g" wire also and wait about 90-120 seconds and see if the fan goes off... if all goes off then either you thermost is still calling heat for some reason or you have one of those wires touching the "r' wire somewhere making the call for heat....
***** if you are turning the thermostat to off and the unit is going off then you most likely just have a bad thermostat and for some reason one of the relays are stuck on thermostat
Jan 13, 2011 | Honeywell Programmable Thermostat Heater
Heatpump r-22 rudd system,unit runs starts out heating then compressor stops in middle of heating ,this unit has a out side air temp. sensor just wondering if possible bad board or not
If compressor stops in middle, check the following.
1.Thermostat setting must be minimum +3 degree than your room temp
2. Check it's in heat "mode"
3. Check indoor and outdoor coils are clean.
4. Check fan motor is working alright.
5. Outside sensor and room air sensor is placed correctly.
6. Gas pressure is o.k
7.Check compressor is overheated, even all the above is o.k.
Jan 12, 2011 | Ruud UAPA024 Air Conditioner
My furnace fan will turn on as if the furnace is going to run, then the pilot lights the burner but with in 3 seconds it shuts off. Could this be due to a bad thermostate
Hello
No i don't think your stat is bad as the unit is trying to run.There is a temp run switch in the plenum of the unit that could be causing this problem.
Its located in the metal box on top of the heater,it may be mounted externally also.
What this does is it senses air temp and tells the fan to run or not run.
You may also have a post ignition problem causing the burner to shut down.
Nov 26, 2010 | Heating & Cooling
I have two ptac units, both want to run 5 or 6 mins. and cut off
Make sure there is nothing in front of the units, Chair, Couch ect, if you take the cover off the Units, you will see a little black Thermoster attached to the coil.
If the air bounces back off of something then it will cool that Thermoster and shut the unit down before the desired room temp is acualy reached.
Also make sure your Thermastat control knob is turned far enough to the right so that its asking for more cooling, Or desired temp.
Hope this helps.
Good Luck!
Oct 26, 2009 | GE Zoneline Deluxe Series Cooling &...
Freezer unit won't shut down
yes the thermostat could be the problem. or depending on the model contol board.rarely the compressor may need to be checked for proper freon levels
Sep 16, 2009 | Freezers
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Sudden overheat
hi  ernie try changing the thermostate first as this can cause this  D
Jan 03, 2009 | 2001 Jaguar S-Type
Penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
26 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
