Question about HP DeskJet F4280 All In One Printer InkJet
I changed ink cartridges and now there is an error sign and low ink black ink sign
Exactly the same problem I'm having. I contacted HP online tech support, but nothing they said fixed the problem. They sent me a new cartridge - still nothing. I'm anxious to see some answers here.
Posted on Sep 17, 2010
3 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: black ink low, error message 5200
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
nakshatraipu
  • 241 Answers
SOURCE: persistent red light despite changes
You have to reset your printer thorugh a module.
www.nakshatraworld.com
Posted on Jan 05, 2010
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
The orange light is lit up on the printer. What does this mean?
There is a problem with the printer. Press resume button again and see if the light orange light goes off. If not then switch off the computer wait for sometime and start again. If it still persists read the error code.
Jan 18, 2011 | HP DeskJet 940c InkJet Printer
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Black ink low, error message 5200
Jan 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MFC-240c ink erros. says i'm low/out after replacing
Your printer detects ink levels with an optical sensor that shines at the clear plastic in the center of the bottom of the cartridge. Once this area is no longer dark it will tell you to replace the ink. Since you installed full cartridges it could be that the sensor is cracking up. Another possibility is that you could have air in the ink lines that run between your cartridges and the print head. When this happens the printer cannot print the color that has air in the lines. You should be able to look in your printer to see the ink lines and see if there is air in the black one.
May 31, 2008 | Brother MFC 240C All-In-One InkJet Printer
I have error 29 on my 210c
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
Nov 14, 2007 | Brother MFC 210C All-In-One InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
76 people viewed this question
Seeker5211
Seeker5211
