Question about Polar FS1 Unisex Heart Rate Monitor Watch
In was trying to replace my battery and the little silver plate feel out . i put it back but can not get it to work now. I just need a picture to show me how the silver and gold parts lay. Debbie
    Problem Solver:
  • 3 Answers
Here is a video that shows the entire process of replacing the battery in the Polar fs1. It shows the little plate and where to place it.
Posted on May 17, 2012
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Did/does Cartier make tank watches that are gold
ARMANI does NOT DO that. Plating is applied to stainless steel only. Rate me, plz.
Posted on Feb 04, 2010
Blank displayI have tried to reset this with no success Any ideas will be gratefully welcome
Have you considered that a dead battery might be the cause of this. They don't last longer than a year. I would not attempt to change the battery on your own if you would miss this watch if you broke it. I change batteries nearly everyday and the digital ones are by far the most difficult. If you did change the battery on your own already the reason it is not working is because you negated to short the battery. Digital watches sometimes need to be shorted after a battery replacement to turn back on take a pair of metal tweezers and put one end on the positive side of the battery. Look for a little hole with a contact on it that's either A/C or reset. Put the other end of the tweezers here. If that doesn't work a tiny spring feel out of the watch is not replaceable and you must therefore replace the watch if that is the case. Hope this helps.
Dec 27, 2013 | Citizen Skyhawk Eco-Drive JR3000-51F Wrist...
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
How do I change the battery in my Casio F-105
When I didn't see an answer, I tried it anyway since I already had the battery and little to lose. Undo the 4 small screws holding the back on (careful - don't drop them). Be careful to keep the small rubber gasket around the edge in its grooves. Do not take the workings out of the watch. There is a small silver arm running across the back over to a cream colored plastic piece with 3 grooves in it. Pieces of the arm are in the outer 2 grooves. Use something small to pry open the arm using the middle groove . Peel it back just a little and replace the battery. The watch should now be working. Snap the arm back in place, be sure the gasket is in place, put the back on,
and screw in the screws. Simple when it works.
Jun 19, 2011 | Casio Watches
How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    Battery replacement procedure for Casio 901 DW-5600?
    hi, if the back plate on the watch the part that is against your wrist has four screws holding the silver back plate onto the actual watch then you need to undo these four screw, once undone you lift the back plate off and then this gives you access to the battery, the screws are small philips (cross head screw) so you will need a small screw driver, their is also a little bracket that holds the battery in place you can either push this over to allow the battery out or undo the small screw that holds this bracket in place this will then allow the battery to fall out,
    If their are no screws in the back plate then all you need to do is get a very fine flat head screwdriver and look around the edge of the back plate and you should see a little bit on one of the edges that allows you to put a screwdriver into to allow you to lever the back plate off if it has no screws then its just a push fit so just pry the back off and this will give you access to the battery then like above the battery will be held in place by small bracket undo this then remove the battery.
    when fitting the new battery make sure you dont touch the top and bottom of the battery as this will flatten it really quick so just push it in place then refit the bracket then either push the back plate back on or screw it back on depending on the type of back plate once this is done you watch will be working again
    Aug 14, 2010 | Casio DW-5600E-1VCT Wrist Watch
    Is it worth trying to replace battery of my heart rate monitor
    You certainly have had good service out of the battery. It is best left to a watch repairer to replace the battery.
    Feb 10, 2010 | Polar F4 Heart Rate Monitor Watch
    Polar CE0537
    you need CR2032 lithium batteries. They can be found on amazon (pretty cheap). here Finally charging for our multi device world
    click on the link and chose some (by price or vendor...) I hope this was helpful. cheers
    Aug 20, 2009 | Polar A5 Wrist Watch
    Replaced battery in lorus digital watch, now the alarm won't work
    The alarm spring proabably was lost. If it was, it will not alarm again.
    Jul 01, 2009 | Timex Advanced Data Link 53722 Wrist Watch
    Pulsar battery replacement
    Pulsar battery replacement can be found at amazon, here: Rayovac Batteries Lasts as Long Costs Less. Best of luck
    Jul 20, 2008 | Pulsar Watches
    Changing the batterys?
    There's little clips on the sides of the plate. You poke a tiny precision screwdriver down there and flick them open, carefully.
    Jul 02, 2008 | Watches
    Polar FS1 Unisex Heart Rate Monitor Watch Logo
    278 people viewed this question
    Top Polar Watches Experts
    NOEL
    NOEL
    David Payne
    David Payne
    Are you a Polar Watch Expert? Answer questions, earn points and help others
