Question about Bosch 24 in. SHU43 Built-in Dishwasher
Wash arms do not move - Bosch 24 in. SHU43 Built-in Dishwasher
  • Bosch Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rackclean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Sep 16, 2010
Dishwasher starts up and then stops after a while giving Error Code F5
check the wash pump is working, to do a test put top and bottom spray arms in a straight line so both are faceing the door and turn on if spray arms are still in same place then it might be the wash pump, if the arms don't move you need to test for power to wash pump and test wash pump
Dec 03, 2013 | Washing Machines
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
The top spray arm is not moving
Hi and welcome to FixYa, I am Kelly.
Take the sump apart from the inside of the tub and clear the debris from under the lower wash arm support. (remove the wash arm support and clean inside) There is a plastic ball in there that moves side to side to pass water to the upper wash arm. The ball is not moving due to debris.
Thanks for choosing FixYa,
Kelly
Jul 30, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aid dishwasher not cleaning dishes well. especially the top rack. practically taken the whole thing apart can't find any clogs.
sounds like you have a broken chopper. have you checked the chopper how far have you taken it apart? if the unit is put back together point all wash arms in the same direction turn the dishwasher on after it has started washing give it about 2-3 minutes open the door and see what wash arm is not moveing. if the upper wash arm is not moveing you need to check the chopper.
Oct 18, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
I have a GE profile dishwasher that is about 5 years old. The problem I am having with it is that it just doesnt clean the dishes. The soap sometimes doesnt alway disolve. the water is the correct temp....
Start the cycle, then after it fills with water, open the door. Move the wash arms so they all point directly to the front and put a mark on the ends with a magic marker. Close the door and let it run 10 seconds or so, and re-open the door. If any of the wash arms did not move, clean out the holes in the wash arms (seeds, candy wrappers, twist ties, bones, broken glass, etc.). You may also need to clean out the screen at the pump inlet, but usually the spray arm holes are the problem.
Sep 17, 2009 | Dishwashers
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
I have a fridgidaire quite 1 built-in dishwasher aprox 10 yrs old . Its not cleaning dishes sounds funny,and soap is staying in dispenser. Have any advice
first check the wash arm ... check the holes in the wash arm . make sure that they are not plugged.
next check that the wash arm is moving . spin it to check that it is free.
next check that there is water pressure to move the wash arm... let me know
Dec 15, 2008 | Frigidaire 24 in. FDB635RF Built-in...
GE Triton XL Dishwasher
Make sure wash arms are going around. Set the arms to point right at you and mark with a marker (so you can tell if the arms moved, not just turned 180 degrees) and run the unit for a few seconds. If the spray arms don't move, look for obstucted holes in the spray arm(s). Toothpicks, plastic candy wrapers, seeds, etc. If all clear, so an "Ask Me" for other ideas.
Sep 02, 2008 | Dishwashers
Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Nov 17, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
237 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
