Question about Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder
Comcast switched us to now use their Digital converter box. I set up the blaster to tell the box to change channels - and it worked - for a while. Then, suddenly - it stopped working. The blaster sends a blast but now the cable box changes to the "Digital Music Menu". It doesn't matter what what channel I want - I get the Digital Music Menu". I exchanged the Comcast box for another of the same (since it used to work) , but same results with this box. So I must be the Showstopper.
  • 238 Answers
Here is a link to "Troubleshooting" of the manual.
Hopefully, it will help you
Posted on May 30, 2017
4 Suggested Answers
  • 69 Answers
SOURCE: No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Posted on Oct 14, 2009
SOURCE: Nikkai 2727 Video sender will not send signals
check that you have the sender plugged into the sky box and the receiver into the required tv and not the other way round. The wrong way round still allows the controller to change channels but you will see nothing also ensure that both sender and reciever are on same channel 1 to 4
Posted on Feb 22, 2010
  • 11800 Answers
SOURCE: I have a Panasonic PV-HS Showstopper DVR. I am
Sorry, your box isn't officially supported. Your only hope is to do a scan, maybe a set of commands destined to another device will match yours.
Posted on Aug 16, 2010
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Comcast cable channel one off from Tivo channel
I've never, ever heard of this problem - having been a happy TiVo user for over 15 years. The very first thing I would do is call Comcast and tell them what is occurring. How long had everything worked OK before this happened? If things were OK for a long time before this, and if your TV carrier was, likewise, Comcast for a long time; and if you haven't gotten a new TV or cable box for a long time, then the problem must rest with Comcast. It must!
In our home, with the number of movies, shows/sporting events/etc. which we record, that would be totally unacceptable!
Try this: Unplug everything (with everything turned off). Make sure your TiVo remote is good (fully charged batteries and the code is right for your TV/cable box), Wait for 10 minutes and plug everything back in, starting with TiVo, then the TV, then any other accessories.
Plug back in and do a complete restart from scratch - like you did when you first set up TiVo.
Make SURE that your receiving channel (3 or 4) is the same on both. It could be that someone accidentally has changed it - are there kids in the house?
If none of this works, get Comcast in there. That's all I can tell you. . .
Apr 11, 2017 | Tivo Televison & Video
I have a panasonic Omnivision Television (model PV-C1330W) that i have just connected to a digital converter box. Now i can't get the comcast remote to connect to my television. Any help?
with comcast you shouldn't need a converter box- unless it's an older comcast system. call comcast and request a digital ready system box. we have comcast and have had no problems with the digital switch-over.
didn't need a converter box.
give 'em hell!
good luck!
Sep 29, 2009 | Televison & Video
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Will not record digital channels
first make sure the cable is running through you vcr then make sure you vcr is set to either channel 3 or one of the inputs
May 06, 2009 | Philips MWD2206 DVD Player/VCR
Local Comcast provider is switching to more digital programming
you will need the adapter and the good news is, the box is free, the downside to this is the panasonic recorder is going to need to only record on channel 3 or 4(there is a switch on the back of the comcast box) and the comcast box will need to be on the channel the program is on. I.E. Panasonic recording channel 3 or 4 from 10-11 am comcast box on channel 55 during that time.
Apr 21, 2009 | Panasonic DMRES15 DVD Recorder
FLM3232 will not receive channels directly from Comcast Cable
Use the TV/Cable rf jack and auto program the TV.
Mar 16, 2009 | Polaroid FLM-3232 Television
Digital TV Converter Box
I have a Panasonic TV with built-in VCR, I had Comcast put in a converter box and was given instructions on how to set up the system to record my wife's programs, I had to select the program (in advance of scheduled time) to be recorded through the TV & converter box to the VCR. Next styep- select "Show" and I received a menu the first of which was "R" I clicked the "R" and a menu for selecting Repeat record start/stop times appeared Click OK and was then directed to to set up the VCR according to Panasonic VCR instructions. Worked for a day then the "R" menu on the converter box disappeared. Both the VCR and TV had to be set to Ch 3 to get it to work, But that's history. When it quit working ("R" menu), I had Comcast come get their box . PS The tech who showed up to pick up the converter box knew nothing about any "R" (record) menus except on the most ecpensive converter box. That cinched my decision, Oh Wel!. Sign me Tom with less trash to watch.
Jul 29, 2008 | Toshiba MV19N2 19 in. TV/VCR Combo
Channels are not available on phillips tv
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
