Question about Maytag MSD2756G Side by Side Refrigerator
Freezer works perfect- fridge is not cooling- no air flow. frost built up and cleaned out. thanks
  • Maytag Master
  • 17,130 Answers
The build up frost is blocking the free flow of ccool air circulation by the fan .So the auto defrosting circuit must eb checcked, check if the timer works, if so the heater swittches on to defrost, if not check the heater. Also check if the thermostat is working so as to cut off the compressor when the set temperature is reached than to keep it running.
Posted on Sep 16, 2010
Fridge s/s cool on freezer but no air cooling fridge side
First, inspect the back wall of the freezer for frost build-up. Defrost failures are a common cause for incorrect fridge temps, and the frost will block air-flow even if your damper is wide open. if there is no frost, verify that the evaporator fan in the freezer is spinning, THEN check the damper door to see if it is open during cooling. Call a tech, guessing will likely lead to a broken machine and/or tons of wasted money!
Apr 26, 2016 | Refrigerators
My GE PSS23MSWSS refrigerator will not cool
Yes the defrost heater part=> WR51X10101 Defrost Heater Assembly and the=> WR50X10028 Defrost Thermostat. The parts are location 230 and 240 in the photo=>
HERE. I am here if you have questions, Thanks, John Tripp Appliance 911
Jan 27, 2014 | GE Profile 23.1 Cu. Ft. Side-by-Side...
FREEZER HAS TOO MUCH FROST AND COOLING, MIDDLE AND LOWER SIDE HAS LESS COOLING WHIRLPOOL 175 MODEL
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
More freezing on the freezer means there is frosting Now you have observed that the fridge after working for about 24 hours does not cool , check if the fridge cuts off. If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Aug 24, 2011 | Refrigerators
Freezer working but no cool air coming into fridge
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
Aug 17, 2011 | Samsung Refrigerators
The freezer cools half way top, below is warm.
Jul 14, 2011 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
My son left fridge door open, from 1-2 hours. it doesn't seem to be cooling now. Is there a problem or does it take a while for condensor to come back on?
What has happened is that the evaporator (the cooling coils inside the freezer) have frosted up due to all the moist air which entered the refrig with the door open. This frost has blocked the normal flow of air within the refrigerator/ freezer. Turn unit off, unload freezer, and leave freezer door open for several hours to allow built up frost to melt. Better yet, remove the panel at the back of the freezer and melt the frost off with a hair blower.
Dec 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge doesnt work but the freezer working as last week i switched of & its working good after but again the same problem fridge cool & temp 5
1. make sure frzr fan motor is running.
2.if so, the check air flow coming out of vent in freshfood side.
3.check for heavy frost built up on frzr rear wall panel.
4.make sure compressor and fan motor are both running.
also remove toe grill and clean condenser coil under refrig.
Jul 14, 2009 | Whirlpool ED2FHSS Side by Side...
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
50 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
