Question about Samsung WEP850 Bluetooth Headset
How do you pair the wep850? thanks - Samsung WEP850 Bluetooth Headset
How do I get the speaker to pair?
Ted,
what are you pairing the headset with? make & model
Jan 08, 2015 | Radio Communications
What is the numeric keycode for pairing bluetooth? Jabra BT2035
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
Both blue & red lights were on. I held the button until it powererd down. Hold again until the blue light flashes 5 times but now the blue light stays on. Can't seem to get it to function. Any tips...
Your headset will automatically go to pairing mode if it is turned on without having paired to other devices before. The pairing mode is indicated by the steady blue light. To pair your headset whilst it is in pairing mode, make the other device's bluetooth application (e.g. phone, computer, etc.) search for new devices. After a while, the WEP850 will appear on the device's screen. Select it there, and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process between any two bluetooth enabled devices should be performed just once. All subsequent connections should be achieved just by bring them both within each other's range. Otherwise, a simple press on the headset's talk.button should suffice.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if you need further informations.
Regards, Carlos
Aug 24, 2010 | Samsung WEP850 Bluetooth Headset
Pairing instructions and code for pairing
paring what? please complete information thanks ^_^
Jun 03, 2010 | Anycom HCC-250 Bluetooth Headset
Help pairing my H12 bluetooth
I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
Dec 29, 2008 | Motorola Mobility Motopure H12 Bluetooth...
How do you put the LG earpiece in pairing mode???
0000 worked great for my LG to Motorola Headset Pairing. Thanks
Mike
Oct 11, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Paired with old phone, can't pair with new phone.
have ya phone ready to almost pair. Then on the 850 ear piece press the call button until lit and then open boom up and press the phone pairing ok button and the 850 should work. waaala!
See how easy that was.
Oct 08, 2007 | Motorola Mobility HS850 Consumer Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Samsung WEP850 Bluetooth Headset Logo
136 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
