Question about Kenmore Ovens
I have a free standing stove/oven, model #790.94111402, Serial # VF51340715. The display shows "Erros F10". Please help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F10 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
Need knobs for Lady Kenmore free standing stove. do not have model # stove was installed when home was built in 1990
parts need to have the model number sometimes the part with have the number etched on to it
Feb 01, 2015 | Kenmore Ovens
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I NEED TO KNOW WHERE I WOULD LOCATE A MODEL NUMBER ON MY WHIRLPOOL GOLD FREE STANDING STOVE
open the draw on the bottom and look at the frame and you'll see a tag with the model and serial numbers,depending on how old it is if the top lifts up it could be there if not down behind the draw
Apr 25, 2011 | Ovens
How do I find the model or serial number on my stove?
If this is a free standing range open the pan drawer and look on the leg.
Otherwise,raise the top surface lid and look under there.
Apr 03, 2011 | Frigidaire Ovens
What does it mean when the oven beep and F10 is on the screen
Go online and type in your model number and ask what the F10 code means. Every stove is slightly different. Mine did the same thing and the F2 code came on. Meant the sensor was gone and I replaced it in 10 minutes for under $80. Even a novice can do it. Perhaps same with yours, perhaps not.
Jan 08, 2010 | Kenmore 33169 Gas Single Oven
Stove shuts off and posts F10 on readout
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 30, 2009 | Whirlpool RBS245PDS Electric Single Oven
What does F10 display on my stove mean? Frigidaire Model PGF355DS
my frigidaire oven keeps flashing f10 and turning off
Apr 02, 2009 | Ovens
Beeping F 10
Hello
Welcome to fixya.com
You r answer to the F10 code is:
The F10 error code indicates a runaway oven temperature. This would indicate that the oven temperature sensor or the electronic control has failed. According to the service manual you need to unplug the range & after restoring power the oven continues to overheat you will need to replace the electronic oven control.
This a job for a hands on tech!
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign out!
Thank You
Dec 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Clock
What country are you in. This model does not show up in Kenmore USA
Perhaps you gave me the serial number by mistake, rather than the model number?
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
57 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
