Question about Kenmore Dishwashers
Leaves water in bottom - Kenmore Dishwashers
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 16, 2010
DU940gwdg3 dishwasher does not wash well. Top, bottom and silverware come out dirty
Is the heating water element getting hot? Is the filter screen in the bottom of the basin clear of food debris? Do you pre-rinse the items being washed?
Apr 21, 2017 | Dishwashers
I have a five years old kitchenaid dishwasher that leaves water the in the bottom sometimes. I have replaced the drain pump and checked the drain hose for blockage but I still have the same problem of...
Propably you have leak from the main pump impeller seal.See the video below. It helped me to fix yesterday same problem.
http://www.youtube.com/watch?v=RLkMncM6JDE
If you open the bottom of the dishwasher you can see the leak.It leaves calcium at the base of the pump.
Sep 10, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
Water leaks from bottom of refridgerator
Automatic defrost units have a drain for the melt water to leave the cabinet and travel to a pan under it. That drain is sometimes not easy to find and it may be clogged with debris or mold so the runoff can't leave as it should.
Oct 24, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Dishwasher isn't draining all the water when used.
It will leave some water for the motor prime but check your drain hose make it is up at the correct angle so water does not come back in when it drains
Oct 21, 2009 | Whirlpool Dishwashers
First time using it and it doesn't drain properly
All the newer ons will leave a little water in them.
They will not drain all the water. It will leave the center part in the bottom with water. the reason is that when the pump cuts off the water that is in the line will come back to the washer.That is just the way they are. There is nothing wrong with it.HOPE this helps.
Sep 22, 2009 | Dishwashers
Bosch dishwasher is not draining all the water at end of cycle. In the bottom of the dishwasher under the mesh trap there is about a cup of water remaining after each cycle.
This is normal with a Bosch. They don't really vent out when they heat, and use a type of evaporation technology to dry the dishes. Best bet is to make sure first that the filter in the bottom is clean, (the little circle thingy on the bottom, turn it a quarter turn and pull it out, run it under cool water till it's clear, then put it back in the same way.) If the water is bothering you or is beginning to make a bit of a smell in there, leave the door cracked a little after you empty the dishes out. unfortunately though, it'll always leave water in the bottom. European technology.
Sep 06, 2009 | Bosch Dishwashers
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Standing Water
are you leaving it long enough to finish it's programme or are you opening it when the drying light is on as some dishwashers leave a bit of water in the bottom to help with the drying programme
Dec 08, 2007 | Dishwashers
Dishwashers Logo
35 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
