Question about Marantz DR-17 CD Player
My Marantz DR17 CD recorder works fine with TDK CD-RXG 74 min discs, but not with the modern 80 min version. The recorder freezes when updating the TOCs. Are there any currently available audio CD-Rs that this recorder will work with? Thanks.
Sony Music CD-R's available at Target (purple packaging not red - must be music not data). I had been using the TDK's from Costco until I started having issues similar to yours. Sony's work perfect - no issues ever.
Posted on Oct 19, 2011
I need audio cd-wr discs to work with this machine
MAXELL CD-RW XL-1180 MUSIC
OR
TDK CD-RW AUDIO 80 MIN
There are lots of other brands to, like sony, memorex, philips, etc.
The two listed above have the all important logo on them as follows......
COMPACT DISC "DIGITAL AUDIO" REWRITABLE
Mar 07, 2014 | Philips CDR775 2-Disc CD Recorder
I HAVE AN OLD 74 MIN COMPACT DISC RECORDABLE FOR CONSUMER CD-R AND I CANNOT WATCH IT FROM ANY OF MY DVD PLATYERS OR COMPUTER OR LAPTOP WHERE CAN I WATCH
That would depends entirely on the file format employed in its creation. If you can display the files on a PC try to determine what software will open it/them up and go Googling for whatever it needs.
Apr 01, 2011 | TDK CD-R 74 min. 650MB Media Recordable CD
A cdr630 twelve years old will not record on any blank discs optical fail on maxell tdk and all brands.do you know what discs i can buy for this machine.marantz state discs with a green dye but i cannot...
The manual states that 74 minute 650MB 1-4X disks run best; my machine would not burn anything I had, eventually I found 650MB crrw's on ebay for as cheap as 2 cents a piece, I have a fair number of them and so far every single one has worked. Imation 800Mb cd's seem to work 80% for me.
May 20, 2010 | Marantz CDR631 CD Recorder
ION LP2CD LP vinyl record records to Internal Fla...
Same just happened to me. I was using SONY CD-R audio 80 min recordable CDs. One burned 3 songs, the other 4 songs before giving me the "CD write failure" message. I tried another brand of CD-R, TDK CD-R, certified plus, and it worked first time. It played on my CD player, on the Ion, etc - works. Maybe the CD burner in the device is very picky as to the brand or quality of the CD-R media? Try a TDK or other to see if that will do it.
-Good luck! Bill
May 19, 2010 | Computers & Internet
Where can I get CD-R's that will work on this machine in Australia these days? ie Are there any non audio marked CD-R's that will work in it? I have tried Verbatim and TDK CDr's without any success. I have...
I don't know about availability of CDR-A or -Music in Australia but they are the only media that home CD Audio Recorders are designed to use.
Regarding the CD-RW Audio disks - I've used them for quite some time and do eventually get uncorrectable errors on them but never No Disc displays. Just the same, I don't consider them reliable enough for vital long term storage of music and use my PC to copy them to a CDR as soon as I can. Being a data- rather than real-time-music copy, I reckon the PC may be able to retry errors it encounters and maybe correct them during the copy.
Feb 06, 2010 | Marantz DR-4050 2-Disc CD Recorder
Can't finalize disc
wonder if thers firmware update for that model try anther cd just make sure not bad disk ok maxwell reg ones just fone always burn slower then needed also cheak website for firmware updates if avb
Oct 06, 2008 | Marantz CDR631 CD Recorder
Disk Recover message and trays are locked
I have had the same problem. To reset the machine when this happens: 1.Switch off with front panel switch (display dims, but still shows same message). 2. Switch off at mains socket, leave off for about 15 seconds. 3. Switch on at mains socket then front panel - machine should then start up as normal.
I have experienced the "disc recover" condition several times now, when a radio recording has run to the end of a disc, and for some reason the recording process has not terminated properly, resulting in the loss of the recording. I found by trial and error that if you switch the mains off at the socket without first switching off at the front panel, then the disc can become corrupted and useless.
I suspect it is partly dependent on the make of disc as my current batch of TDK RWs do it almost every time, whereas with my last batch (can't remember if they were Maxell or Memorex) seemed much better.
I think the only way to prevent the problem is to manually stop the recording before the end of the disc is reached, I suspect possibly before the 74 minute 'red-book' CD limit is reached, even on an 80 min. disc, though I haven't yet tested that theory properly.
Hope this helps,
HifiJohn
Aug 31, 2008 | Philips CDR796 2-Disc CD Recorder
Trouble with cdr 570 philips
Newer discs are made with different dyes. We no longer get philips discs in the UK but Maxell 80 min discs work great in my 570. Have you ever been able to use 80 min discs? Usually if a machine only accepts certain types of disc it means the laser's power output is reduced i.e it's worn out so it may be time to find a new machine unless you can get a supply of discs it does use OK.
'Mr Audio' discs from Mr Data should be avoided at all costs.I can only use them in my Sony machines.
Feb 24, 2008 | Philips CDR570 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Marantz DR-17 CD Player Logo
735 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
