Question about Microsoft Xbox 360 Console
Xbox360 QUES. console is very noisy, ecspecially when disc in drive. sounds out ofbalance.
  • Tom Kilroy
    Tom Kilroy May 11, 2010
    What does it sound like?
    Like a high powered fan?
    Like the CD is spinning very very fast?
    Like the CD is bring scratched inside the tray?
  • 25 Answers
I have heard of this problem before.
Simply look on the box that the Xbox came in and contact the customer service line, they will let you send them the Xbox and repair it for you free of charge, and ship it back to you in about 3 weeks working perfect!
hope this helps :)
Posted on May 17, 2008
When I put any disc(game or cd) in my xbox360, it
When last did you clean the pick up lens on the console?
Sounds like the pick up lens is not reading the disc, any hard collisions on the console recently? If you have the correct lens cleaner at hand I would advise a cleaning asap, see if this solves the issue.
Oct 24, 2013 | Microsoft Xbox 360 Console
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
My xbox 360 loads in but when i put in a game it dosent load in the game
You could temporarily upload all your games to your xbox360 hard drive using your pc to play or buy a new disc drive but you would have to flash the firmware or manually swap the bottom internal boards inside of the new disc drive with the old one.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
Nov 13, 2009 | Microsoft Xbox 360 Console
Xbox360 disc drive
Hi, it sounds like you have the" open tray" error that is very common with the 360s. How you fix this is you take your DVD drive apart and look at the laser assembly, there are 2 screws on the side of it, look at the one on the left. Turn this screw to the left a VERY little bit at a time and keep checking it every time you turn it until it stops the open tray error.
Aug 17, 2009 | Microsoft Xbox 360 Console
Xbox will not read any game or dvd
It sounds like your DVD drive has failed, this is fairly common. There is a good chance it is still under warranty from microsoft. Give them a call at:
800-4-My-Xbox
If it is not under warranty you can replace the dvd drive itself, google xbox 360 replacement parts. It's not too difficult if you are technically inclined.
Jun 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't play old xbox games?
If your console is hooked up to Xboxlive and has a Hard Drive connected to it you will automatically be prompted to update upon insertion of the original Xbox title. Your console will restart when it's ready and you should be able to play.
*If you do not have a Hard drive you cannot play original Xbox titles.* The original Xbox Memory unit will not work in Xbox360 and the original Xbox games have no access to the Xbox360 memory units.
If you have a Hard Drive but your Xbox360 is not hooked up to the internet you can either order a disc for free from Microsoft by going Here
or burn the needed information onto a disc by going Here
Dec 26, 2008 | Microsoft Xbox 360 Console
Xbox360 disk drive wont do anything
sounds like disc drive needs to be replaced
Nov 15, 2008 | Microsoft Xbox 360 Console
Problem with xbox360
Try and open the dvd drive and clean the laser and the cd spinning motor with qtips and rubbing alcohol and see if that works. that is the most probable cause.
alex
Jul 08, 2008 | Microsoft Xbox 360 Console
Xbox360 game will not read
If your xbox is modded try a different brand of disc.
Obviously try and clean the disc itself.
Else your dvd drive is faulty and needs to be replaced
Mar 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
21 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
