Question about Panasonic KX-TG5632 Phone
Installing a new base unit
How to set up to install a base unit i have 3 already and they work fine
however i purchased another one today and it keeps saying
refer to manual to prepare base then press ok i keep trying to do this but it doesnt seem to work what am i doing wrong?
    Novelist:
  • 106 Answers
You will need to press the page/locator button and hold it down until the charge light flashes. Once you do this, go to the handset and push OK. It should register as handset 4. Hope that helps. CG
Posted on May 26, 2008
New broiler unit installed and not working.
Try unplugn it..alotta stuf today is about reboot...u mayhav a fuse or module at issue....checout utube
May 10, 2015 | Kitchen Ranges
My vtech dect 6.0 keeps saying unable to call try again
I had this happen suddenly on 2 out of 3 handsets with a DS6151 base and DS6101 handsets. Well, what happened is there was no dial tone on either of the 2 handsets on either of the 2 lines and a message appeared on the display "Unable to Call Try Again" after some delay, if Line1 or Line2 button was pressed.
Oddly, the 2 that did not work were the ones normally on "extension" chargers and the 1 that did work was the one on the base unit. That caused me to suspect the base unit .. which it still may have been but the solution was NOT. And, also odd, the handsets seemed to still be synched with the base unit in many respects.
Cycling the power on the base unit did nothing.
These are fairly new units and battery life is generally much longer in my experience.
The Solution:
- Remove the battery from the handset that doesn't work properly.
- Re-install the same battery.
Whatever was wrong, this reset it and the handsets started working again.
Easy fix.
Mar 18, 2012 | Vtech DECT 6.0 Digital Cordless Phone
I have an Audiovox Overhead DVD player in my 2006 Ford Explorer which was installed at time of purchase. It doesnt work at all and I just want to replace it with a better one. My question is, are there...
You can possibly use the old base but it will depend on the video screen. the new unit will absolutely need to be connected to the radio. Some web sites to ponder on www.millionbuy.com and www.onlinecarstereo.com and www.etronics.com these sites have good prices. Hope this helps leave feedback if so. thanks
Jun 06, 2010 | Car Audio & Video
A while ago I put a larger sd card in to my unit,as i wanted to install the complete maps of the U.S.A, i PUT A uLTRA 2 GIG CARD IN, IT WORKED FINE, PUT MY GPS AWAY FOR A FEW MONTHS, YESTERDAy i put the...
Most likely you got a hot copy of the maps and it worked fine for a few minutes in the new unit. Check the course of the map because they know if they are purchased new or are being copied. Not saying you did anything wrong just saying the SD card can only be used for one unit. Contact the company and they will set you straight.
Apr 30, 2010 | Tomtom GO GPS Receiver
New oven won't work and can't set time, display keeps blinking
Hey--  You've spent a bunch of time on this already, so let's figure it out. The first step is to check power connections. L1, L2 , Neutral for proper location and tight connections. Should have 120v and 220v checked at bus block. If these check out, then this new unit should be under warranty and qualify for service. Not unheard of bad board or loose wire on a new unit. Let a tech sort it out on site. Let me know if this info helps- have more if needed-  Thanks-  Ed
Mar 15, 2010 | Whirlpool Ovens
1998 VW Beetle AC cycling on and off
**** in the venturi valve ,remove the ac interior unit and clean it all out ,broken bits of the old compressor blocking the restrictor (venturi )
Oct 23, 2009 | 1998 Volkswagen Beetle
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Cheers,
Matt Coyote
Feb 20, 2008 | Car Audio & Video
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
Surius Can not find antenna
A couple of possibilities all based on the assumption that the unit actually turns on.
1. Broken or disconnected antenna wire.
2. Broken antenna (The antenna is powered from the unit)
3. Broken unit.
Dec 27, 2007 | Sirius Satellite Radio Receiver
6 months old. Now no water will fill drum! Works as normal but no water!
Hurlewan Your washer is still under manufacturer's warranty which is one full year. If it has Kenmore's name on it you do not need proof of purchase. The only thing you need is your mother-in-law's home phone number at time of purchase because Sears keeps all their records based on phone numbers. Good luck, Gendos post back....
Jun 27, 2007 | Kenmore 43142 Front Load Washer
Panasonic KX-TG5632 Phone Logo
62 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
