Question about Karcher 2500 PSI Pressure Washer
My Honda VR 2522 on Excell 2500 psi pressure washer run good when in use but when i release the trigger on the wand the motor idles and begans to pulsate, hit and low. Where to i start looking to repair. I have a new air filer installed Roy
  • 174 Answers
SOURCE: Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Posted on Aug 25, 2009
Dolfoff
  • 148 Answers
SOURCE: i just bought a 2nd hand honda excell psi max vr
Have a helper hold the trigger of the wand open while you try it again. If it starts that way you have a sticky unloader valve in the pump. DO NOT RELEASE the trigger for more than 10 seconds if the engine continues to strain when released! If the engine doesnt run freely when you let go of the trigger, pull it again and shut down the unit!
Add some power steering fluid to your supply hose (about 3 or 4 ounces at a time) and restart the unit with the trigger pulled. Allow the oil to flow through the pump for 1 - 2 minutes for each treatment. Several treatments should make the pump and valve happy again.
Hope this helps.
Posted on Sep 28, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Pulsating when idle
The motor doesn't pulsate when you are spraying and pulsattes when not spraying is normal otherwise the pressure will just keep building and burn out the pump. However, if you are not using the sprayer right away then the unit should be shut off until your ready to start again.
I hope the answer is helpful, please rate if the answer has helped in any way. Good Luck and have a great weekend.
Posted on Apr 04, 2010
  • 8 Answers
SOURCE: let go of wand trigger pressure will not come back
spill valve is stuck and needs to be cleaned and greased common problem....also check all connections for blockage in line
Posted on Jul 25, 2010
wmpcs
  • 100 Answers
SOURCE: have a Honda Excell VR
If they are the tires with the plastic rims then there was a recall and a local service center can replace them for free, if not I have tires that fit on this unit in stock, price is $13.33 each, send me a email at justin@wmpcs.com
Posted on Nov 09, 2010
How do I keep wand from blowing off trigger
Push it on and turn it, it should lock in place,
Jul 11, 2014 | Honda 2500 PSI Gas Pressure Washer
Where to install thermal relief valve
It should be the last threaded hole right before the water enters the pump itself, on the low pressure ( inlet) side, most pumps have 2 different size holes 90 degrees from each other, commonly 1/4 and 1/8 in.
Dec 13, 2012 | Honda Karcher G2400HH-R Pressure Washer
Devilbis Excell pressure washer with Honda engine runs smoothly without wand, but stalls when wand is attached.
If the pressure unloader is not working correctly and/or the nozzle is partially clogged with debris, the engine will be overtasked. Try lowering the pressure by turning the pressure knob to lowest setting and test. If the engine continues to run, gradually increase the pressure. Try using the washer set to about 75% of rated capacity and use max pressure for stubborn stains. Using any machine at max will shorten the life of components. If lowering pressure does not help, then unloader is faulty or stuck. Try storing the unit with oil in the pump. Remove both hoses and infuse oil into water inlet intill all the water is displaced (let set for day or two). Good luck
Sep 27, 2011 | Karcher 2500 PSI Pressure Washer
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
Let go of wand trigger pressure will not come back
Jul 21, 2010 | Karcher 2500 PSI Pressure Washer
I just bought a 2nd hand honda excell psi max vr 2522 2.2 gpm max 5.5 hp gvc160. i put gas and oil and it wouldn't start?
Hope this helps.
Sep 25, 2009 | Karcher 2500 PSI Pressure Washer
Hello awcockerill:
Aug 24, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
701 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
