Question about Dishwashers
Have a 14 year old Kenmore Ultra Wash III dishwasher. Just lately, the glasses/dishes/silverware feel "grimmey" and I can see streaking on glasses and residue on silverware. I use jet dry and up til recently have had sparkling dishes. Any advice?
SOURCE: Dishwasher smells like pond scum
I have the SAME problem with our dishwasher. It's disgusting. Between the fishy glasses and the garlicky ice cubes (NO, we don't have garlic in our refrigerator or freezer -- purchased ice doesn't smell), I'm embarrassed to pour our guests a glass of ice water!
Posted on Jul 28, 2008
blueextc3221
  • 15935 Answers
SOURCE: streaks on glassware/silverware
usually indicative of clogged spray heads, or spray arms not spinning, too much detergent for your water type, wrong detergent, and low water temp.
Link to manual:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203381187.pdf
Check the manual for amounts of detergent to use based on your water hardness.
Posted on Jan 06, 2009
localwonder
  • 6784 Answers
SOURCE: white film/residue left on dishes
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. Dishwasher Magic is a good choice. works great.
Posted on Jun 18, 2009
  • 677 Answers
the problem is hard water. www.dishwasherfilter.com has a new product out that solves this problem once and for all. it filters the water going into the dishwasher removing the hard minerals that leave those spots. it is very affordable and guaranteed to work or your money back. you will love the way your dishes look.
Posted on Jul 26, 2009
  • 677 Answers
SOURCE: White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Posted on Nov 09, 2009
Where can I order a bottom rack for 19 year old Kenmore Ultra Wash III 16779?
May be difficult to find due to the age. Sears carries a lot of Kenmore replacement parts.
Mar 31, 2016 | Kenmore Dishwashers
I have just moved into a home with a 1 year old Whirlpool Gold GU2400XTP Quiet Partner III. THE DISHES ARE NOT CLEAN, GLASSES HAVE WHITE SPOTS, SILVERWARE AND PLASTICWARE HAVE WHITE FILM. I am using...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is not quite 2yrs. old and has always worked great until now. Top rack cups and mugs still are dirty inside from coffee, lipstick, etc., glasses have spots and are cloudy, and silverware...
Welcome to FixYa,
Based on your description I`d suspect a plugged wash pump.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undesolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it. It is not really referring to the heating issue, or maybe even your model, ( Most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air ) but it is the same procedure.
When you`re finished run it through a test cycle and see how it goes.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Aug 19, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Etching on the glass ware and the dishes don't come clean.
Dishes may not be getting enough rinse water. Had the same problem before I replaced inlet valve. My fisher packel was 3.5 years old before I replaced the inlet valve due to a knocking noise, but It still ran through cleaning cycle without any alarm codes.
May 17, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Dibris on glasses afterwash. Dishes not coming clean
First check salt level is ok, the next thing may be it's having problems pumping out after the primary wash.
Try running a hot cycle with a dishwasher cleaner or 2 cups of washing soda, then pull out outlet hose and check it's clear.
Check all filters are clear and in good condition with no cracks.
Aug 05, 2009 | Thermador DW44Z Built-in Dishwasher
The dishes don't get clean
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 | Dishwashers
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
