FixYa.com
Tags:
Air Conditioners
Generic problem for all Air Conditioners
Dehumidifier is work but
posted by number1dylan on May 17, 2008
dehumidifier is work but is not geting any water it is boling not sucking dose this normly happn y
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 17, 2008
Not Rated (0)
22yooper
Rank:Guru Guru
Rating: 85%, 348 votes
A dehumidifier normally discharges the air out the front and the air circulates through the space and returns with more moisture to the back. If you are getting no moisture out there is a possibility your unit may have lost its refrigerant charge. Is the air coming out warm or equal to the temperature of the air going in. If this is the case you have the same indication of a lost charge.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Coleman Mach III Air Conditioner GE APN10AA Portable Air Conditioner Panasonic CW-C60RU Air Conditioner Panasonic CW-XC104HU Air Conditioner Continental CE-PAC1163 Air Conditioner DeLonghi Air-To-Air Portable Air Conditioner DeLonghi (CF210) Portable Air Conditioner
Can you Help with these Air Conditioners problems?
Air Conditioners
20 ton trane voyager roof
20 ton trane voyager roof top... Answer This...
Air Conditioners
The front grill is frozen
The front grill is frozen with... Answer This...
Air Conditioners
CHANGING OUT A FAN MOTOR
changing out a fan motor on a... Answer This...
Air Conditioners
The pilot light has always
The pilot light has always been... Answer This...
Air Conditioners
i just purchased a CT90/CT110
i just purchased a CT90/CT110... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
