Question about Texas Instruments TI-84 Plus Calculator
My trignometery calculations are off by one-two points. What can I do to fix it.
  • Texas Instru... Master
  • 7,993 Answers
I am not quite sure what you mean by "OFF BY ONE-TWO POINTS".
If you have a problem of "precision" you can increase the number of digits that the calculator displays.
  1. Press [MODE]
  2. Use down arrow to highlight the line FLOAT 0 1 2 3 4 5 6 7 8 9
  3. Use right arrow to move cursor to one of the numbers on the line and press [ENTER].
  4. The number you will select will set the number of decimal digits displayed.
Keep in mind though that most of the "precision" one may be seeking is illusory.
When doing trigonometric calculations make sure the angle unit set in the calculator is the one your problem requires (deg, radian.)
Posted on Sep 19, 2010
I don't know if maybe my calculator has a function turned on that rounds the answer to a whole number? But here is an example: 106 x 6.32 = 670 according to my calculator, which is wrong. The real answer...
Your calculator is set to display no digits after the decimal point. To change this, you have two options: press 2nd [SCI/ENG] then select "FLO" for floating decimal or press 2nd [FIX] then select the desired number of digits after the decimal point (or F for floating).
Feb 14, 2014 | Texas Instruments TI 30XIIS Scientific...
I want it to return to the 0 level it's 0.000000000
Press the setup key (to do this press 2nd F and then MATH). Now press 1 for FSE and select NORM1 by pressing 3. Your calculator should go back to normal. Alternatively, reset the calculator by pressing the reset button on the back of the calculator.
Nov 07, 2012 | Sharp EL-506 Calculator
How do I set to Scientific Notation?
Press 2nd [SCI]. You can specify the number of digits after the radix point by pressing 2nd [FIX] and a digit key.
SCI is on the 5 key, FIX is on the decimal point key.
Jan 27, 2011 | Texas Instruments TI-30XA Calculator
My TI-30Xa circa 1995 has suddenly started rounding up on the 1/10 digit. How do I correct this or is my calculator fried?
Press 2nd [FIX] then the number of digits you want to the right of the decimal point. [FIX] is on the decimal point key.
Nov 07, 2010 | Texas Instruments TI-30XA Calculator
How can I turn off the Fix key on my TI-15?
The FIX indicator tells you the calculator is set to a fixed-decimal mode. To clear this mode, press FIX . (decimal point).
Aug 22, 2010 | Texas Instruments TI-15 Explorer...
Tonight my calculated started ending each answer in zeroes. I never have had this before. What is wrong?
First of all,what kind of calculator do you have? I suspect you inadvertantly changed the floating decimal point to a fixed one. That would give lots of zeros. Look at your calculator and find mode. It should be set on floating point.
Dec 01, 2009 | Canon P1-DHV Calculator
Decimal places
To put the calculator back to NORMAL mode, try [2nd][FIX] then [ . ] (decimal point).
Oct 05, 2009 | Canon F-502 Calculator
I have too many zeros after the decimal point and I need to delete them. How do I do that?
If got to do with the mode settings. Usually MODE fix in other lower version of calculator. The combination can be MODE FIX 0 for no trailing zero's if MODE FIX ONE then if will 0.0 or one zero then shifting the settings to NORMAL mode and at DEG mode.
Jun 26, 2009 | Casio FX-115ES Scientific Calculator
There is a button in a vintage textbook showing a calculator with a "FIX" button. What was that button for?
Followed by a digit key, it probably set the display to fixed decimal notation with the specified number of digits following the decimal point.
No, it didn't magically fix a broken calculator :-)
Mar 26, 2009 | Casio HR-100TMPlus Calculator
Trignometery: prove that .....
THIS PROBELM IS TO DIFFICULT SO PLEASE SLOVE THIS PROBELM
Oct 07, 2008 | Computers & Internet
Texas Instruments TI-84 Plus Calculator Logo
63 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
