Question about Bunn Dual TF DBC Coffee Maker
I have a Bunn/TF DBC that we keep having boards and heating elements going out on them (we have placed 3 different Machines)...I have had electricians telling me that the building power is fine and the it is not their lines...any ideas.
    President:
  • 1,618 Answers
If the electricians are saying that the lines are and that there are no brownouts, then I would open the front panel on the machine and check that the terminals wires are correct, then the plug, then the outlet(I have been to places where the ground and neutral have been swapped at the outlet). If all that is correct, use your voltmeter to check incoming power between the red and black wires for 220 and the red and white, and black and white for 110. For so many heating elements and boards to go out, tells me that either the machine is running out of water, and the elements are overheating but the hi-limit reset switch should have caught it in time to save element. If you still have the old boards I would check them to see which part burnt out then you can have an idea if it is a power thing or water or solenoid or level control.
Posted on Sep 16, 2010
Bunn troubleshooting
If you are pressing the secret button behnd the trademark symbol but its not working, you need to make sure the SET dip switch is set on the main PCB. switch off and isolate the machine. Remove the top cover. look at the main PCB behind the front panel and locate the small dip switch on the right side. Set it to the on/Set position to enable the secret button
Mar 10, 2014 | Bunn Dual TF DBC Coffee Maker
Hi I have a bunn commercial brewer. its a sh dbc brewer. the brewer keeps heating the water all thw way to 225 degrees and keeps going.
Sounds like the thermostat needs to be replaced adjusted or the probe to the thermostat is covered in scale, and it cannot read the temp correctly. Remove top panel and check probe, if fine no buildup, follow probe line to thermostat and set to a lower setting, if same problem replace thermostat.
Apr 02, 2011 | Bunn Dual SH DBC Coffee Maker
The hot water spout is not dispensing water properly. The flow rate is low. its not the spout itself, I've replaced it... The water line appears to be unobstructed... Any idea what could be blocking the...
Mineral build up, remove the top panel and clear hose to boiler, you will have to turn machine off and remove hose at boiler and use a small screwdriver to clear fitting on boiler.
Nov 24, 2010 | Bunn Dual TF DBC Coffee Maker
How do i adjust the water flow from the hot water dispenser? I need it to come out faster.
If your talking about the hot water faucet the flow rate can't be adjusted.There may be a blockage from lime at the tank fitting.You will need to clean fitting of lime.
Nov 06, 2010 | Bunn Dual TF DBC Coffee Maker
I have a Bunn Dual SH coffee brewer that does not dispense the same amount of coffee every time
The problem is either the liquid control board or there is something blocking the solenoid, or drawing water from the same line pressure. Also check the sprayhead for buildup.
Oct 26, 2009 | Bunn Dual SH DBC Coffee Maker
Cleaning the thermos on the BUNN single TF DBC
For the thermos you can use a small amount of purocaff and fill the thermos with hot water, let sit over night then rinse with cold water a few times to clean you can also use a soft brush to clean while the purocaff is in thermos. Clean around the showerhead with a clean towel, or you can use a filter with a little purocaff and brew into thermos and clean both in one shot.
Mar 23, 2009 | Bunn BREWWISE Single TF DBC Coffee Maker
Slow recovery on bunn o matic for next cycle
You could have scale building up on the heating element and thermostat probe. try running a 1/3 white vinigar - 2/3 water mix into the brewer, let it heat up completely, then run several pots of clear water through the unit. keep pouring water through it until the vinigar smell is out of the water,
Jan 05, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn Dual TF DBC Coffee Maker Logo
104 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
