Question about Wacom (PTZ930AC) Graphic Tablet
My Intuos3 Wacom Tablet doesn't work...sometimes
I've had my Intuos3 (A4) for just over 2 months now, and it has worked pretty much ok (well, the pen has at least). But, since yesterday, the pen has been acting oddly. It is fine as long as it stays inside the range of the pad, but once it leaves it, it won't work again until I press and drag for about 15 seconds. The blue light is still on, and the mouse still works. I have restarted my computer, unplugged the tablet, reinstalled it and still it isn't fixed. If anyone can help, thanks a lot.
I have this issue and the tablet is plugged directly into the machine. I am currently diagnosing what the problem could be and suspect it's a power thing, or lack of. I also can not use the tablet during gdm as it screws it up when the a user logs into either a kde or gnome session.
Posted on Nov 04, 2009
I had a similar problem with the tablet not picking up the pen until I waved it around (in range) for a few seconds.  I realized later that the slow response time was due to me having the usb plugged in to the monitor instead of directly into the computer...  I switched and all is fine now.
Posted on Jul 13, 2008
SOURCE: My Wacom Intuos3 tablet won't switch into pen mode
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
Posted on Mar 22, 2009
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Posted on Aug 14, 2008
SOURCE: wacom intuos3 pen is not working
A few hours ago Wacom released a new driver 6.1.2-5 for the Windows 7/Vista/XP operating systems. I was having the same problem. Hopefully this will be a permanent fix!
http://www.wacom.com/downloads/driver-detail.php?id=200
Posted on Nov 26, 2009
SOURCE: My Wacom Tablet won't recognize the pen.
you have to install the pen on the CD you have from the box you got it in
Posted on Apr 21, 2010
SOURCE: Wacom tablet (Model ET-0405-U) Driver?
see i am having the same problem. i am runing windows xp but the tablet light is yellow and does not go green. and does not work at all i have also downloaded et driver.
Posted on Jul 22, 2010
Why won't my wacom grip pen click when it touches the tablet instead of hovering and selecting text?
Have you tried pulling the nib out (the end bit you draw with)? It could be that something is sticking the nib further inside the pen than it should, which is telling the pen you are applying pressure. As far as I know there is a little spring inside the pen that the nib pushes on when you touch the pen to the tablet. Perhaps the spring is permanently squished in.
May 26, 2014 | Wacom Intuos3 Grip Pen
My Wacom pen doesn't work. The blue light on the tablet turns green when I touch the pen to it, but the cursor doesn't move on the screen. I thought that the tip needed to be replaced, but after changing...
Does the mouse work (on the tablet)? What happens when the side buttons are pressed do they work? Try un-installing the Wacom driver (Pen Tablet Utility) and Install the latest version from www.wacom.com and see if that helps.
Mar 05, 2011 | Wacom Intuos3 Graphic Tablet
Apr 21, 2010 | Wacom Intuos3 Graphic Tablet
My wacom pen does not work at all, the mouse on the tablet does though
on some older pens, the barrel can spin out of position. If your barrel turns, it can mess up it's function.
Turn the barrel until you hear or feel a clicking into position and try again.
If that doesn't work, move wacom cable to a different usb port. worse case, replace pen.
Mar 14, 2010 | Wacom Intuos3 Graphic Tablet
Wacom intuos3 pen is not working
Nov 19, 2009 | Wacom Intuos3 Graphic Tablet
Wacom GP110 pen tip replacement
Just grab the tip with a pair of tweezers and pull it out. It'll come out pretty easily, and you can slide the new tip in its place.
Mar 26, 2009 | Wacom Intuos3 Graphic Tablet
Feb 04, 2009 | Wacom Intuos3 Graphic Tablet
Wacom Intuos3 stopped working when I upgraded to Leopard
I did solve it myself. Having downloaded the new drivers off the Wacom website, I hadn't realised they were still sitting on my desktop waiting to be installed. Once I found the folder and opened and installed it everything worked fine!
Sep 10, 2008 | Wacom Intuos3 Graphic Tablet
Jun 23, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Wacom tablet doesn't work
Probably a driver problem, update or reset the drivers for it.
Sep 02, 2017 | Wacom Intuos3 12x19
Wacom (PTZ930AC) Graphic Tablet Logo
3,648 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
