Question about Epson PowerLite 5350 Multimedia Projector
I have a double image using my 5350 Epson PowerLite
  • 1 more comment
  • jmuehlheausl Sep 16, 2010
    I have tried other computers and wires with no luck.
  • jmuehlheausl Sep 17, 2010
    I read up on this problem and talked to a person who said it was a mirror problem. I was hoping someone would know how to adjust something inside the unit that would fix this problem. I was a VCR/computer repairperson for years but never fixed a projector.
    I will try this solution. Thanks
  • 629 Answers
Often, this is related to the connection between your computer and projector. try to use another set of working VGA cable and change the screen resolution to 800 by 600 when using the projector. It may also help to test the projector on another computer to help isolate the issue.
Posted on Sep 16, 2010
  • Rodie Sep 17, 2010
    if it has same issue on another computer using a different video cable, and using 800 by 600 or 640 by 480 resolution, chances are, it has something to do with the projector components itself like the LCD panels of the projector or even the lamp. you can try to use compressed air to clean the LCD panels and make sure the LCD panels afre all connected properly. if you continue to experience the same issue, you might need to get the panels replaced or get the projector serviced.
    I will try your suggestion. Thanks
    President:
  • 2,923 Answers
If you are connecting your projector to the computer using the RS232 (Serial) connection, you may try changing the COM port under the Device Manager on your computer.
Go to Control Panel > Systems > click on Hardware tab > Device Manager.
Connect your projector using the serial connection (while Device Manager is open). Then another device should appear under Ports (COM & LPT).
Expand the Ports (COM & LPT) > open the device > go to Port Settings > click on Advanced button > change the COM port.
Thank you and good luck!
Projected image too small
Did you replace the lamp with the EXACT type that was in the projector prior to changing it? Sounds like there is difference in lamps.
Feb 26, 2014 | Epson ELPLP42 PowerLite 280 Lamp
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
Epson projector bulb won't turn on when rpalced
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Apr 18, 2012 | Epson ELPLP09 Projector Lamp for PowerLite...
My Epson Powerlite 5350 has a ghost image. Any recommendation on how to adjust the projector to remove this symptom?
I've got the same problem on two Epson EMP7300.
I believe (from reading about other projectors) that the ghost image can be adjusted with RS232 codes.
Does anyone know how to do this?
Jan 24, 2010 | Epson PowerLite 5350 Multimedia Projector
One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
Dec 09, 2009 | Epson POWERLITE 400W Projector
Epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Epson PowerLite® S4 LCD Projector
Epson Powerlite 5350- reset lamp timer
5350:reset the lamp timer
1,While simultaneously holding down MENU and Help on the control panel
2,While simultaneously holding down MENU and UP on the control panel
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 18, 2009 | Epson ELPLP09 Projector Lamp for PowerLite...
Double Image
It's may be the video cable from the PC. I had the exact same problem with my Epson projector today. Treat y
Oct 06, 2006 | Epson PowerLite 5000 Multimedia Projector
Epson PowerLite 5350 Multimedia Projector Logo
1,930 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
