Question about HP LaserJet 3055 All-In-One Printer
Paper Jam in HP 3055
While scanning a document, the paper jammed in the feeder. Now it is stuck and there is no way to take it out
Please let me know how to get it back and restart the scanning
  • abuarab May 19, 2008
    Paper was jamed in the feeder. The paper was soft. When I pulled it some parts of the paper remained in the feeder. No access to clean the feeder.
  • humbleguy85 Dec 16, 2008
    I cannot scan the copies. its showing the " doc. Feeder jam". how to remove the paper from it. it is stuck inside the paper.
Here's what's worked for me. Get a flexible plastic mat, cut to paper width, then force it gently through the feeder to push out the paper bits. These plastic mats, sold to be used as cutting board in the kitchen, are very inexpensive.
Posted on Nov 07, 2008
    Genius:
  • 2,785 Answers
Just check in the back if there is any part can be removed if you dont find then you have to open the printer(there will be screw or latched)
Posted on May 17, 2008
4 Suggested Answers
  • 105 Answers
SOURCE: HP laserjet 3055 has Document feeder jam errror
It sounds to me like the switch that senses when paper is present is blocked or out of position.
The User Manual and such does not provide sufficient detail for me to decipher what type of switch is used. It is either going to be a switch that is depressed to close the circuit when paper is present and is held down somehow now, or it is a proximity sensor and there is dirt or whatever on the sensor that is enough to make it think there is paper there. It should be something that appears to be a tiny window, and it would need to be cleaned with a qtip or 100% cotton cloth and isopropyl alcohol.
You will likely need to remove the ADF feeder cover to obtain full access to the ADF mechanism and find the sensor, since it is most likely recessed in the ADF quite a ways.
The other possibility is that the wire for the sensor has been damaged after a jam or something of that nature.
If you have searched for the sensor and cannot locate it / clear the error, then you will need to have a service tech work on the machine.
Posted on Jun 20, 2008
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Posted on Jul 27, 2009
  • 81 Answers
SOURCE: documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Posted on Sep 15, 2009
I am printing several pages and there is a jam. I
It will re-print it after you clear the jam. Just pull it out pulling slowly and evenly and it will come out.Also you can see directions on HP.com. Steven 818-888-0006
Mar 06, 2010 | HP LaserJet 3055 All-In-One Printer
I have a jam in the auto feeder, paper is stuck and I can't take it out.
Please follow all the steps here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01345627
Thank you
TechSaver
Feb 06, 2010 | HP LaserJet 3055 All-In-One Printer
Documnet feeder jam
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
Doc.feder jam
Try cleaning the rollers in the ADF (Automatic Document Feeder).
It might temporarily solve the problem, but rollers do have a limited life time, so you will eventually need new ones.
Part info:
5851-3580 - Automatic document feeder (ADF) paper pick-up roller assembly
Price: $15.57
Dec 10, 2008 | HP LaserJet 3055 All-In-One Printer
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Paper in document feeder
there is no paper in document feeder
May 24, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
962 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
