Question about Sony Handycam DCR-TRV33 Mini DV Digital Camcorder
Can not get sound when capturing video
I am trying to capture video via USB streaming and can get the image fine but it has no sound. Anyone know what I am doing wrong.... very frustrated
You have to use a firewire cable to capture video.With USB you don't get sound
Posted on May 25, 2008
I installed the Pixela Imagemixer and hooked the hadycam to the computer. Everything is fine accept the sound. How can I get the audio problem solved?
The currently bundled PIXELA software does not default to the correct audio settings. In the ImageMixer [Tool settings], confirm the USB Capture Device settings are set for an available [USB Audio Device]. This setting is not defaulted to the USB streaming mode.
The available USB audio device may be displayed as Sony Digital Imaging Device or USB Audio Device. When these choices are available, the Sony Digital Imaging Device should be selected.
If you are having any installation questions or problems with the PIXELA software, please let me know.
Thanks for understanding.
Mar 30, 2011 | Sony Handycam CCD-TRV608 Camcorder
Using sony dcr-sr36 as a webcam
Unfortunately is not possible directly - Your cam do not support USB streaming... But You may use any cheap video capture device like Pinnacle Studio movie box or similar to connect Your camera via S-video cable because Your camera has an analog output. Only one requirement - the capture card must have an S-video input or simply RCA video input. It's easy - connect video out and audio out of Your cam to the capture device and then connect USB of capture device to Your computer.
Sep 19, 2009 | Sony Handycam DCR-SR40 Camcorder
Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
Mar 12, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Easycap usb adapter - shows images from video but there is no audio sounds
i c ant get sound on my pc,driver detactive saying i neet up date multimedia audio controller,anyone can help me p,lz?
Sep 16, 2008 | Leadtek Winfast PVR 2000 (663001C) Video...
Sound is not recorded
The problem would appear to be your audio settings.
You have the audio input set to Realtek HD Audio Input. That is the audio input on your soundcard, not the video capture card. You will need to change this so that you have the capture card selected. (I am not familiar with this exact model of card so I can't tell you exactly what it will be called.)
Alternatively, if you are trying to capture the audio via your soundcard (not recommended as it can cause sync problems) you will need to make sure that the 'line in' channel in enabled in the Windows mixer:
Start>Control Panel>Sounds & Audio Devices>Audio Tab>Click Volume in sound recording section>Tick Line In
Hope this helps,
Matt
Mar 06, 2008 | KWorld V-Stream Xpert VS-L883D...
Computer mode
hi follow this steps: Make sure that you have installed the USB driver for the handycam. You can download the drivers from this link: Sony Asia Pacific Support Website--Download Page for HC40E USB Driver for Windows. Connect the handycam to the AC adaptor (the same as putting it on charge). Set the handycam to USB stream mode. (Press P-menu, press MENU, Press EDIT/PLAY, Press USB MODE, Press USB Stream.) Set the tape at the point from where you want to start capturing in PC. Connect the handycam and the PC with the USB cable. (USB-Mode appears on the handycam LCD / viewfinder.) Start Windows Movie Maker. Click on the 'Capture..' link to start the wizard. Select the Sony Digital Imaging Device. Click Next. Specify the file name and path for the capture video. Click Next. Select the desired capture format and Click Next. (Leave it to recommended setting if you are not sure.) The dialog box now displays the Start Capture and End Capture buttons on the left and preview window on the right. Play the tape on the handycam. The video from handycam should appear in the preview window of WMM. Click the Start Capture button to start capturing the video. Click End Capture to pause or stop recording. Click the Finish button. The .wmv file will be saved in the path specified in step 7.
Oct 02, 2007 | Sony Handycam DCR-TRV265E Digital...
I have no sound on my sony handycam
Sony got back to me with the answer, so I will post it here for future reference.
If there is no audio when USB streaming with PIXELA ImageMixer version 1.5 software on the Microsoft Windows XP operating system, change the USB capture device setting for sound to USB Audio Device. In the Image Mixer Tool settings, confirm the USB Capture Device settings are set for an available USB Audio Device. This setting is not defaulted to the USB streaming mode.
This would be the icon of an open end wrench in the top right hand corner of the capture environment screen.
Follow this procedure to change the USB capture device setting for sound in the Pixela ImageMixer 1.5 software.
1. In the ImageMixer window, click the USB Device Capture icon.
2. Click the Preferences icon.
3. In the Capturing/Recording Preferences window, in the USB Capture Device Setting section, click the down arrow to select the desired sound device.
4. Click the OK button.
For any request for processing or editing assistance you may visit the PIXELA help file. You may also contact them at the following website:
www.imagemixer.com
Jul 04, 2007 | Sony Handycam DCR-TRV265E Digital...
Gr-d290
Hi, You can only transfer still images (photos) with a USB cable. For video, you need a firewire card and cable. That's the way it works.
Mar 17, 2007 | JVC GR-D290 Mini DV Digital Camcorder
No Sound when Capturing
ah. This happens to me sometimes. Well, for some reason it always works when i first open USB streaming tool( this program is not for recording)use the program to edit the video, like to fix brightness etc. Then open capturing tool. This is what you use to capture the video to your computer. What i do is to press the play button in the program, not the capture button. The video on the camcorder and the video on your screen should start playing. I do this just to test the video if its gonna have sound or not. Then you rewind the video by pressing the rewind button in the program. After that press the capture button. Sometimes it records and you don't hear the sound on the computer, I'm not sure but maybe after its captured into the computer, the video will have sound. If you do record, but with no sound, record about a minute and then stop it. Go to where you saved the video and check if there is any sound. Hope this helps you. Sorry if it's kinda confusing because i don' use the program no more. I use a DVD recorder which you connect your camcorder to the DVD player and it burns the video directly to a DVD. Its much mroe easier but you can't play around with it on the computer.
Jan 12, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Unable to play Audio after Video Capture
I happen to have this setup... you need to set the audio source (the usb camera connection.) It is possible to hook up via the sound card, but that could be stressful for some.
Sep 14, 2005 | Sony Handycam DCR-TRV38 Mini DV Digital...
Sony Handycam DCR-TRV33 Mini DV Digital Camcorder Logo
73 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
