Question about Husqvarna Chain Saw 20" Bar
My Husqvarna 136 S/N 91VG/56 runs about 1/2 min. then dies. Start it again and it runs about 1min. and dies.
  • 784 Answers
Check air leaks between cilinder and carburator, if its ok- fine, check rebuid carburator.
Posted on Mar 18, 2011
Starts but wont stay running
spark plug or coil. replace plug first
Jun 14, 2016 | Husqvarna Garden
04 chv p-up 4.8 5sp start an run 10 to 15 min then dies might start 1 more time for 30 sec an die again then start again an gages r trip in an radio
The very 1st thing you need to have done is a scan of the control module for fault codes. You will need a OBD2 code reader for this test, cost about $40 US
May 21, 2016 | Chevrolet Cars & Trucks
HUSQVARNA 128LD WILL START RUN FOR A FEW SECONDS AND DIE.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
Aug 22, 2014 | Husqvarna 128 LD Weedeater
Why is it failing?
open gas cap and see if it will run again. m,any times the gas tank vents clog and the engine can't draw gas after a few minutes.
another thought is the oil mixture.. 50:1 with oil made for air cooled engines....not boat engine oil
Apr 02, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Rancher 55 will start and run for approx. 30 min. Then will shut down and not restart until completley cool.
Could be a couple of things, when it satrts to die, just slacken off the filler cap, if it picks up again then it is a fuel tank breather issue, the other possibility is the igniton unit breaking down when hot, the only answer here is to replace the unit.
Aug 31, 2011 | Husqvarna Garden
Stops running AFTER A COUPLE MINS
If it starts OK and runs fine for a few minutes you may have debris (dirt) in your gas tank. The dirt settles on the bottom, you start the motor and through vibration and shaking the dirt gets mixed up in the gas and sucked onto the fuel filter until the motor starves and dies. When the motor dies the dirt settles back on the bottom and you start all over. With the motor off, shake the gas up well and drain the tank into a bucket so you can check for debris. If there is a lot, half fill the tank, shake it up and drain again. Also, you may want to check your gas can to make sure the debirs isn't coming from there.
Sep 23, 2010 | Husqvarna Chain Saw 18" 450 Model...
I have a Husqvarna 125BT blower. It runs fine but
GAP is the opening between terminals at the end of the spark plug ( on the threaded side of the spark plug) but spark plugs should come with the right gap from factory, as for your problem with to restart your blower it is ok just need to let cool down for 15 min or more.
May 15, 2010 | Husqvarna Forest & Garden 125bt Backpack...
My 2008 BMW 1200 GS will not start. It cranks over fine but will not start. Yesterday when I left work it started fine but after 1min it died. I restarted it and it died again. Finally got it started and...
Most likely your fuel pump regulator that is malfunctioning.
It is located under the LHS top panel, more or less in line with the instrument cluster.
Apr 24, 2010 | 2008 BMW R 1200 GS
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
Husqvarna Chain Saw 20" Bar Logo
210 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
