Question about Vivitar ViviCam 8400 Digital Camera
I dropped it now it will not work properly. The zoom will not retract. Is it repairable and where. It switches on for 2 seconds then switches off. Vivitar Vivicam 8400. Not tried to fix it.
    President:
  • 1,194 Answers
Its seems lens got stuck in the barrel due to external shock caused by drooping the device, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else visit this link & contact VIVITAR, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Thanks..!!
Posted on Sep 16, 2010
When using the zoom control, why does the lens zoom out but will not zoom back in with the zoom control?
hi,
your camera's zoom is faulty, there is some sensors with which controls the lens retraction, if the lens's position is wrong the sensor cutting edge will not get in the proper position.
open the camera, take out the lens, open it carefully, if the position of the lens is not in proper position, you can see some marks on the lens barrel fix it in the correct position.
Feb 25, 2016 | Nikon COOLPIX Cameras
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
The zoom lens does not retract on dsc-w1/w12
I've had the same problem on rare occasion. Usually, I just wait a few seconds, then turn the camera on... wait a few more secs, turn off... repeat as necessary. When all that doesn't work, I've replaced with new batteries & the problem is solved.
Feb 07, 2009 | Sony Cyber-Shot DSC-W12 Digital Camera
The lens retractor jammed after falling from bed
it can be fixed.... olympusamerica.com/repair
Dec 28, 2008 | Olympus FE-270 Digital Camera
I need some help to repair my Sony Cybershot DSC W50 camera. When you turn the camera on, it displays 'Access' for about 30 seconds, during which time the lens zooms in and out. Then it says 'Turn the...
when the camera is switched on it turns the lense out to a certain position and locks , but if due to any reason if the lense does not reaches to its proper position it retracts back and tries again 2 or 3 times, and then the movement haults and prompts 'Turn the power off and on again'. there is a friction in the movement of the lense. If you want to fix it yourself, then you have to open the lense assembly , dismantal it clen all the barrels and the groves, remove all the dirt and friction in the movement. refit the assembly and you will get the camera working .
Aug 13, 2008 | Cameras
The lens on my camera won't retract.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon powershot S2IS
1>>u may have dropped the camera in some place.
2>>the camera POWER ON switch must have got pressed while the camera was inside pouch. if this has happened, the lens system gets jammed and so lens wont retract. for this problem it costs nearly 1800rupees in indian service center.
Dec 21, 2007 | Canon PowerShot A75 Digital Camera
Lens does not retract
I'm looking for a solution to this too. The repair is going to cost more than the camera did. SUCKS!!!
Dec 02, 2007 | Pentax Optio M30 Digital Camera
Problems with camera. Help please.
THE CAMERA ZOOMED OUT COMPLETELY AND WHEN I SWITCHED OFF IT REMAINS AS IT IS , AFTER PUTTING BATTERY & ROLL IT SHOWING ( f 1 ) & AFTER SOMTIME ( f 2 ) AND AGAIN IT WILL SHOWING ( f 1 ) ON INDICATOR.
Nov 08, 2007 | Pentax IQZoom 200 35mm Point and Shoot...
Vivitar ViviCam 8400 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
