Question about HP Photosmart 3210 Printer
HP Photosmart 3210 error: 0xb83e5958 Just started after I installed new router. Does anybody know what this error is? Thanks
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 05, 2009
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
  • 57 Answers
SOURCE: hp photosmart 3210
farats -
Follow these directions from HP Support:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&lc=en&dlc=en&cc=us&product=439488&rule=19892&lang=en
If this doesn't work, follow the shut down procedure, then open the cover and see if the carriage is locked by trying to gently push it to your right. It shouldn't move. If it does move, push it all the way to the right, then start the printer up again following the directions.
If you still have a failure, check the supplies to see if they feel like they all have ink in them. If your printer is trying to cycle ink from a supply to the printhead, and the supply is empty, you will get an ink system failure. Buying new supplies to check for this problem is expensive, especially if it turns out not to be the cause, but it also may fix the problem. Your call.
I have seen this issue before and it usually can be fixed quite easily by someone who knows their way around this printer, so a repair tech should be able to fix it if your efforts don't.
Michael
Posted on Jul 11, 2009
suzeroo
SOURCE: Photosmart 3210 - A Printer alignment failed error
Mine has done the same thing.
To fix this you have to reinstall the software, then reboot your computer.
I did that, and the printer alignment function worked fine for a while, then I started getting the same problem again, possibly after I had installed other software not related to the printer -- I don't really know.
In any event, it's doing the same thing again, so I just "cancel" the alignment and continue to use the printer. My prints are fine.
Posted on Aug 07, 2009
pineworks
  • 4041 Answers
SOURCE: error code 0xc18a0001 HP Photosmart 3210 All in
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Photosmart 3210 bought Dubai need to change region Spain
Hello Friend
You can change region settings of your hp 3210 printer by changing your language preferences.Just select the language of your region and it will be fine.
Thanks,
Viju
Apr 03, 2010 | HP Office Equipment & Supplies
Ink system failure error: 0xc18a0007
Look for your specific error. Click the link for reset if your error is not found:
HP Photosmart 3210 Ink System Error
Failing this, your 3210 may require repair service.
I hope you found this document helpful.
Dec 28, 2009 | HP Photosmart 3210 Printer
I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Nov 06, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210 scanner won't work when I installed it on my new computer (Vista). It worked on old computer (Windows XP)
u can download driver from this link for ur hp photosmart 3210 scanner . just click on link and click on download only and save into ur pc.after downloading the file u can run and install
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47754-1&lc=en&dlc=en&cc=us&product=439488&os=2093&lang=en
Jul 28, 2009 | HP Photosmart 3210 All-In-One InkJet...
Jul 20, 2009 | HP Photosmart 3210 Printer
Reset the product:
  5. Wait 60 seconds.
Thanks, Joe
May 05, 2009 | HP Photosmart 3210 Printer
No disc
Please download the All-in-One software from below web link :
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47754-1&lc=en&cc=us&dlc=en&product=439488&os=2093&lang=en
Please copy the entire URL and paste it in a new window of Internet Explorer and press Enter.
Thanks
Dec 24, 2007 | HP Photosmart 3210 Printer
Photosmart Essential Lockup
Hey guy don't follow thier suggestion. No one can't do anything for u r problem because Your H.P. inkjet Printer 3210 doesn't work with Vista. I am also faced same problem. It is technical problem. Just change your vista or Printer
Jul 02, 2007 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
