Question about Royal PX1000MX Shredder
I can't remove the basket to empty - Royal PX1000MX Shredder
    Genius:
  • 1,218 Answers
Its probably jammed with shredded paper to the point where the paper is stopping you from removing the basket. You will just have to try to open it enough and "fish out" some of the paper so that the level goes down and the basket can be removed.
In extreme cases if you let the basket overfill then the "shredded" paper gets caught back up in the cutting blades and you can jam the machine and fry the pcb inside.
Posted on Sep 16, 2010
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Nespresso won't reset after emptying capsule basket. Lights flash as if basket is still full or water is empty??
Call company ASAP..
and they may give you a new one..
after my research.. many have a lot of troubles,
some are different than yours.
or call 1-800 555 1212.. for company information
to call company..
Bummer not having Coffee when you want it.
Apr 06, 2013 | Coffee Makers & Espresso Machines
Do you have to buy picnic baskets with cutlery and crockery inside? I really just want an empty basket as I would rather use disposable stuff.
Picnic baskets come both empty and full. You choose whichever one you prefer. Here is a link to the Picnic-Basket site where they have a selection of empty baskets.
http://www.picnic-basket.com/empty-picnic-baskets.html
Feb 27, 2013 | Home
How do you empty the container?
You will first need to unplug your shredder. On either side on the shredder head, there are grooves. These are finger grooves. Place your fingers inside the finger grooves and lift up. This will remove the shredder head from the waste basket. Simply empty the waste basket, replace the shredder head and plug back in.
Jul 10, 2012 | Compucessory CCS 60062 Shredder
Cannot install tray with ground basket installed, after removing. Mechanism is blocking the ground basket when the tray is slid back into the unit after emptying.
Try putting a container under the coffee spouts and pressing the rinse button. This will usually free any coffee grounds that may not have been expelled into the grounds basket from the last time the machine was used. The grounds can get stuck and block the slide path of the grounds basket.
Dec 23, 2010 | Jura Capresso Jura / Capresso IMPRESSA J5...
How to empty full royal vf1000mx shredder. No, the basket does not pull off.
You may have the basket completely full and jammed with paper which is why it won't come out easily.....you will just have to try to slightly lift the basket and pull forwards to remove it.
Jun 24, 2010 | Royal Office Equipment & Supplies
Basket doesn't spin when emptying wash water
remove door switch and tape the wires together, if it works fine now. replace door switch!
Jan 11, 2010 | Kenmore Washing Machines
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Washing machine not rensing well
there is a magic clean filter on bottom of basket. it has been removed from newer models because it builtup **** and never cleaned itself. need to remove agitator and basket to clean tub and remove plastic filter from bottom of basket. special tool required for basket
Mar 14, 2009 | Washing Machines
How do we empty the waste basket?
The "waste basket" is to indicate that the waste toner area in the drum cartridge is full. If the copy quality is still ok you may be able to empty the waste by removing the drum cartridge from the machine and removing the opaque piece from the left side and dumping it out. BE CAREFUL this can be very very messy. toner is a very fine powder and will get all over the place if caution is not used.
Jan 07, 2009 | Canon NP 7130 Black and White Copier
Royal PX1000MX Shredder Logo
247 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
