Question about StarTech.com Ide To Sata Drive Mounted Adapter (IDE2SAT) Serial ATA Controller
I plug my Device into the ide port on my computer, supply the power to it, and hook the SATA data cable to the cd drive. I also supply the power to the cd drive. When I turn the computer on it says that not secondary drive is found. The Ide2Sata has no jumpers on the board. How can I get my computer to read the drive?
  • bibendum
    bibendum Sep 16, 2010
    check bios
  • eastjoshuara Sep 17, 2010
    I have checked the bios, I got on to dell and downloaded the recent update for my bios. Once I downloaded the current updated bios, I flashed the bios and updated it. Still nothing. The website for the Starteck says there is jumpers on the board but there is no jumpers on that board. Any other suggestions?
    Problem Solver:
  • 11 Answers
You need to install the drivers for the card then plug in the card
Posted on Sep 19, 2010
How do I read a barracuda 7200.12 1 TB drive? I need to get data off of it, not boot on it
Hi
The easiest way that I have found is to get a kit that allows you to power the drive from a separate wall socket and connect a data cable from the drive to a USB socket on the computer. Such a kit usually consists of four components:
A mains lead - wall socket to black box transformer
The black box transformer - has outlet 4 pin molar for IDE drives
A USB cable ending in unit for connecting to an IDE drive or SATA cable
A SATA cable for connecting to the SATA drive (your Barracuda 1Tb in this case)
The components can be seen on this Ebay site:-
USB 2 0 TO SATA IDE Cable for HDD with Power Converter Adapter UK
The one thing missing from this set up is a power conversion cable converting the molar 4 pin power connector to a SATA power connector. These can be a molar plug to go into the lead from the black box and either a single SATA power plug, or a double SATA power connector as shown here :
Molex to 2x SATA Power Dual Power Adaptor Splitter Cable Lead Hdd Cd DVD...
This option is inexpensive and offers great flexibility in the type of drives that can be connected to a USB port, 2.5 or 3.5 inch, SATA or IDE.
In your particular case you may be able to get a dock that connects to a power supply and a USB port, with an opening in the top to take a SATA drive. These tend to be more expensive and only suitable for SATA drives not IDE.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Seagate Barracuda 7200.12 1 TB 7200rpm...
Change my gx620 motherboard with ide connector for dvd rom to a 745 motherboard which has sata connection for dvd rom so i purchased a sata dvd rom and sata cable plugged everything in but the dvd rom wont...
With sata there are two cables, just like ide. One is the power and the other is for data. The data cable goes from the device to the motherboard. The power comes from the power supply. If your power supply does not have a sata connection you can purchase an adapter that will turn an available 4pin Molex into a sata connection.
http://www.ebay.com/sch/i.html?_nkw=ide+to+sata+adapter&_sacat=3667&_odkw=ide+to+sata+adapter&_osacat=42017&_trksid=p3286.c0.m270.l1313
Sep 11, 2011 | DELL 8X Serial ATA Slimline DVD-ROM Drive...
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
What cable do i need to hook up samsung ts-h663b 22x dvdrw sata to dell dimension 2400
You are going to need more than a cable to connect a SATA drive to the Dell Dimension 2400's motherboard. The motherboard only supports IDE devices.
Assuming the original power supply, you need either a SATA controller PCI card (and an available slot) and a 4 pin device to 15 pin SATA power converter (like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16812270313&cm_re=ide_to_sata_adapter-_-12-270-313-_-Product)) or an IDE to SATA data connector (like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16812119257&cm_re=ide_to_sata_adapter-_-12-119-257-_-Product )
The IDE to SATA data connectors come in a couple of types. Some plug into the 40 pin connector on the motherboard (and you will need a power adapter); others plug into the SATA drive and usually accept the 4 pin device power connector.
I hope this helps.
(If you have upgraded the power supply to one with SATA power connectors, then you do not need the power adapter.)
Feb 06, 2011 | Samsung Computers & Internet
I have a Dell Dimension E520 running Windows XP. I have a Seagate Barracuda 7200.7 100 gb Ultra ATA hard drive (model number ST3100011A) with IDE connections (taken from an old Emachines). The plan was...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 22, 2011 | Computers & Internet
I'm Hooking up an internal hard drive their is already a port for data on current drive which can be utilized. Do I need an additional sata Cable for power supply?
There is very likely already an available data port on your IDE cable already inside your
system cabinet (unless you're working on a laptop). the only trick is to plug in PIN 1 correctly-
to get it right, check the silkscreening on the PC board for the HDD (Hard Disk Drive).
Power comes from the 4-pin power cable coming from the power supply - in cannot be plugged in
backward, as it is asymmetrrically shaped to prevent backwards installation.
Jan 02, 2011 | Computers & Internet
I need a cord for the mad dog multi media device so that possibly I can have this external hard drive accessed.
What device do you need a cord for? The Mad Dog Dominator given above is an internal IDE CD/DVD drive. Thus it can be connected to a 4 pin peripheral molex connector to the power supply and a 40 pin IDE ribbon cable. Some USB/SATA/IDE devices will be able to connect to the drive for external use (since it is a full size 5 1/4" drive). Similarly, you can find some USB external device enclosures that will work with the IDE connect.
There are IDE to SATA converters that you can add to connect the drive to a computer with no IDE port on the motherboard. (There are also power adapters to convert a SATA power connector to the 4 pin in the rare case that you do not have a free 4 pin connector. However, a 4-pin y-connector is usually a better choice).
All of the above items are available from most computer supply shops.
I wish that I could be of more help.
(external hard drives currently can have one or more of the following connectors: USB 2.0, e-SATA, Firewire, ethernet, or USB 3.0. The USB 2.0 is the most common. A standard USB cable (A/B) is the usual one for a USB 2.0. These are also available at most computer shops. Look at the device and the size of the opening to determine the cable end needed. Standard B is a square end with beveled corners. Usually a text or icon on the device will indicate the port type.)
Oct 21, 2010 | Mad Dog Multimedia Dominator 4 in 1...
Install IDE devices (drives / DVD / CDROM) sata
IDE devices have different "data" and "power" connectors than SATA drives.
So, you need a motherboard with IDE connectors, if you wish to connect an IDE disk-drive (or CD/DVD), and you need a motherboard with SATA connectors, if you wish to connect a SATA device.
Similarly, the connectors on the power-supply must be compatible with the sockets on the disk-drive (or CD/DVD) drives, so that the devices can get power.
You could possibly purchase a short IDE-to-SATA power-adapter, if you have a SATA device, but there are no SATA power-connectors on your power-supply.
May 29, 2010 | Intel Motherboard
How do I install a new CD drive in an old destop computer It is an old Compaq Presario 5WV254 The existing CD drive has a ribbon type connector that mates up to the pins on the drive plus a 4 pin module...
The Compaq Presario SWV254 Desktop PC uses IDE technology, not SATA.
In the specifications for the above Desktop PC, it states ATAPI is used for the interface technology, and connector, for the optical drive/s.
[IDE is also referred to as PATA. Parallel ATA
SATA is Serial ATA.
The PATA designation was implemented, so that computer users could easily distinct between IDE, and SATA technology]
1) The IDE interface cable, (Flat ribbon cable), has a connector on each end with 40 socket holes.
(39 are actually used. Most of the time, one socket hole is blocked off. (Pin 32)
2) The SATA interface cable has 7 contact pins. Also referred to as a Data cable.
3) The IDE devices, (Harddrive and optical drive), use a 4-pin Molex connector for the power cable.
4) The SATA devices use a 15-pin connector on the end of the power cable.
More info on SATA,
http://en.wikipedia.org/wiki/SATA
The Samsung SH223C optical drive is a SATA device.
You cannot just plug it in.
IF, you have an open, (Available), PCI slot on the motherboard, you can use a SATA adapter card.
The SATA adapter card plugs into the PCI slot, and has the necessary connections on the card, for a SATA interface cable.
(NOTE*
Just for the SATA interface cable. Does not have a connection for the SATA power cable, you need.
You have to buy a 4-pin Molex to SATA power cable adapter, and connect it to an available 4-pin Molex power cable, on your power supply.
You will also need a SATA data cable. The interface cable that goes from the SATA adapter card, to the SATA optical drive you're trying to install)
This is an example of a SATA adapter card. It is not an advertisement for said website, nor manufacturer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1281807&CatId=1455
Jan 06, 2010 | Compaq Computers & Internet
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
StarTech.com Ide To Sata Drive Mounted Adapter (IDE2SAT) Serial ATA Controller Logo
83 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
