Question about Microsoft Xbox 360 Console
My 360 has no video signal only sound, i have tried 2 TV/ 1 Projector 2 AV leads/SCART leads,the visuals were very poor shortly before losing video completely.????
  • 4,102 Answers
Hi, if you are getting the sound and no video then this suggests you are on the right channel so you have got the following problem.
the problem you are having will lead to the red ring of death, you get the rrod when the gpu and cpu chip have over heated, as you get the sound and no picture or loss of both this says that the gpu is over heating and needs fixing.
you can try the following
1 switch the xbox off and leave it off for at least an hour
2 check all air vents are free from dust
3 make sure your not using the xbox on carpet or on top of anything like dvd or sky box
any of the above will cause it to over heat so make sure the xbox is not in a confined spaced and not on top of anything else
remove the leads from back of xbox and remove hard drive, plug all the leads back in making sure the leads are pushed in properly in the xbox and back of telly, then if you still have the problem try and borrow a friends video lead to try on your xbox.
if it still dont work then this suggests it has over heated and the damage is done so check if you have any warranty before you do anything with it, then if you have warranty take it back and get it exchanged or if your warranty it out you need to get the gpu and cpu heat sink changed and the x clamps removed and getting this done should get it working.
but you need to know that say out of every 10 i do work on only 2 wont work and would be classed as scrap, i repair these for about 25 quid plus parts which is about a fiver so your looking at roughly them prices to get it fixed, i work on the basis that if i dont fix the problem i wont charge for the work i just charge for the parts used.
let me know if you need further assistance
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 16, 2010
  • 1 more comment
  • paul proctor Sep 16, 2010
    Hi the problem you are having will lead to the red ring of death, you get the rrod when the gpu and cpu chip have over heated, as you get the sound and no picture or loss of both this says that the gpu is over heating and needs fixing.
Cant tune tv in to use xbox 360
Check the scart lead by substitution, try another source of input, (game machine or dvd player,) it,s not uncommon to find bad solder joints on the print, where the scart socket is soldered to the mother board of the telly. there is no tuning as such for scart sockets, but you can get them in the wrong mode? S-video etc? but you should, in that case, get some sort of picture. Good luck! Nick
Mar 23, 2010 | Televison & Video
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
I have a vhs/hq ..i have visual but no audio for a program i recorded last thursday. I tried recording from tv now and still no sound but picture. I played other movies or previous recorded things in vhs...
Try first to ensure that the scart lead at the back of the set or any AV leads that you are using are secure and tight.
Sometimes if the scart lead is not pushed home correctly it will lose audio. Try then to record a sample of video and try playback.
If there is still no sound try another scart lead first.
It will be a process of elimination I'm afraid.
Regards
Marc
Apr 17, 2009 | RCA DRC8300N DVD Recorder/VCR
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
Dec 28, 2008 | Video Game Consoles & Games
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Jan 08, 2008 | Televison & Video
No Sound on recorded programs or TV
this is uaually a problem with the scart lead try changing your scart lead if this dont work are you running you cable box through the video using a scart lead if you are make sure you press av on the video remote controll make sure the leads are pushed in properly this and make sure their in the right socket ie input output but this should not make no difference hopefull this should solve your problem
Oct 26, 2007 | Televison & Video
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
