Question about Kenmore HE2 Plus Front Load Washer
Error code F O2 - Kenmore HE2 Plus Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
I need to know the code dtc44 for a 1990 Buick Century
GM OBD Trouble Code 44
Auto Systems and Repair
Oxygen Sensor Error (Lean Condition Indicated) The ECM receives a signal from the O2 sensor based on the amount of oxygen in the exhaust. If there is excess oxygen in the exhaust, it is in lean condition and the O2 sensor voltage will be low. The ECM uses this information to adjust the amount of fuel delivered to each cylinder.
Fault Code Description
  • 44 - Oxygen sensor error (lean condition indicated)
  • On V-type engines with two O2 sensors, code 44 would indicate the left bank sensor is lean
Symptoms
  • Lack of power
Common Problems
  • Faulty O2 sensor
  • Engine vacuum leak
Dec 01, 2014 | Buick Cars & Trucks
Error Code P0430
this is the o2 sensor after the pre cat so post cat you can get a tune to get rid of code or replace the o2 sensor or get spacer that screws into the cat witch will make it not code the o2 sensor is there to just make sure the cat is there for emissions and will not effect the gas milage
Jul 15, 2014 | 2004 Audi TT
P0421 CODES AND C1201
C1201 error code means that you have some problem in engine control system.
Possible causes for P0421 error
  • Warm Up Three Way Catalytic converter deterioration or malfunction
  • Exhaust system leaks
  • Loose front or rear HO2Ss
  • Faulty front heater O2 sensor
  • O2 sensors harness is open or shorted
  • O2 sensors poor electrical connection
The P0421 code means that the vehicle's control module has detected that the three-way catalytic converter is not working properly (is not as efficient as the factory is expecting). Replacing the oxygen (O2) sensors may sometimes fix the code, but in most cases the catalytic convert needs to be replaced to fix the problem.
Apr 24, 2014 | Toyota Avensis Cars & Trucks
O2 sensor comes back on after second trip
What is the error code you are getting when check light comes on? Check for the code if not done yet as it will assist in solving problem. You checked the O2 sensor before replacing it; whether it was for downstream or not? If Upstream O2 sensor is placed in place of downstream then also the error light comes on.
Jul 01, 2013 | Lands Phones
O2 sensor
Unless check engine light does not come up, there is no need to worry about O2 sensor. To check O2 sensor check your ride for error codes. The error code will tell you which sensor is faulty (If error code says faulty O2 sensor).
Jun 21, 2013 | Audi 100 Cars & Trucks
How to fix 98 cadillac cater error codes
Reset error codes by disconnecting battery for 5 minutes. Start fresh. all codes should be clear now. drive and see if any new codes come on. They are the ones you need to address.
May 15, 2017 | 1998 Cadillac Catera
Check engin light on. There are four error codes P0137,P0141,P0342, and P1792. How do I fix it. Will I pass inspection with these codes?
P0137 Error code Faulty O2 sensor Exhaust leak near the rear sensor
  • Plugged catalyst
  • Short to voltage on O2 signal circuit
  • High resistance or open on O2 signal circuit
Possible Solutions
  • Replace faulty sensor
  • Repair exhaust leak near the rear sensor
  • Check for restriction in catalyst and replace as necessary
  • Repair short, open, or high resistance on o2 signal circuit
P0141 Error code means Downstr Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
- replacement is needed for this issue.
P0342 Error code means Camshaft Position Sensor Circuit Low Input
P1792 Error code means P1792 means the computer isnt properly programmed so if this code keeps comming back the pcm may need to be replaced
Aug 13, 2010 | 2002 Daewoo Lanos
I got error code for bad o2 sensor. and MAF sensor
you're looking at this the wrong way, i suspect you have an engine problem, do a compression and leak down test, also look for a vacuum leak after the maf sensor
May 28, 2010 | 1998 Ford Escort
2000 Ford F150 XLT Error Code P1132 and P1152
Error codes P1132 and P1152 indicate O2 sensors reading rich at banks 1 and 2. Change O2 sensors.
Jun 28, 2009 | 2000 Ford Windstar
Tundra v8 2003, po0136 error code
Thats a o2 bank 1 sensor 2. Its the o2 on the drivers side behind the cat.. Not the one before it.
Mar 20, 2009 | 2000 Toyota Tundra
Kenmore HE2 Plus Front Load Washer Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
