Question about Kenmore 74173 / 74170 Top Freezer Refrigerator
Kenmore 253.78989801. Refrigerator stop cooling, then freezer gradually lost temperature. Melted ice buildup on coils by removing panel in freezer. Restored power. Fan in freezer works, I can hear condenser humming, but temperature inside is still hot after a day.
  • leeks3pl Sep 16, 2010
    That's a good analysis. The refrigerator slowly lost it cooling capacity over a period of a week not all of a sudden.
  • Kenmore Master
  • 17,130 Answers
If freezer is not cooling then the chance of frost forming is also out of question. So we need to start of by checking on the prrimary component, the compressor. Make sure the speed of the motor is humming welll or check the motor capacitor. Use a clamp tester to measure the current factor to see the load. If the pumping is low then check for gas pressure in the unit. If not you will need to check why the gas leaked check the leak with compressed air pumped in and monitored.for leak.
Only then recharge gas and seal.
Test the motor before gas filling to confirm the performance.
Posted on Sep 16, 2010
  • Donald DCruz
    Donald DCruz Sep 17, 2010
    You forgot to rate my views..please.
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
Hi, I have a Kenmore Smart Reach with the freezer swing door. My freezer keeps getting ice on the back panel and my ice stops making. I have defrosted it twice and this helps for about three weeks. Any...
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click for article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Jul 24, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Hello\r\nI am trying to troubleshoot my Kenmore Refrigerator
If the coils are not icing up you do not have a defrost problem. Check that the evaporator fan is operating. Thats the one near the coil. You will need to close the door switch to see if it comes on. If it is working next check that the damper is opening this alows cold air into the fresh food section. Without the full model # I am not sure if your defrost thermostat operates the fan. Check the wiring diagram to see if the t-stat feeds the fan. If it does and there is no power at the fan replace the t-stat.The problem is likely to be either the fan or damper motor. Try this link for more testing info
http://appliancehelponline.com/sxsevapfan.html
http://appliancehelponline.com/sxsdamper.html
http://appliancehelponline.com/sxsdefrosttstat.html
Jun 03, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator/freezer not cooling evenly top to bottom
good then go ahead and ohm out the sensor and the relays to see if the resistance is close to the normat. 70 degrees is roughly 1000 ohms. relay you are lookling for continuity or open. then you can also ohm the fan motor too. let me know what you find;.that will determin whts bad and whats good
Dec 25, 2008 | Kenmore Refrigerators
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
15 year old Kenmore side by side refrigerator
I had the same problem and had to have serveral parts replaced, it was very expensive $600.
Good Luck
Kathy
Sep 21, 2007 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 74173 / 74170 Top Freezer Refrigerator Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
