Question about Western Digital External USB 2.0 80 GB Hard Drive
1 TB WD external Harddisk is not getting recognized
    Sergeant:
  • 203 Answers
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Posted on Sep 16, 2010
My WD Elements SE External drive does not have its driver recognized on boot, but does only after repluging its USB 2.0 connection. How do I get the driver recognized on boot? Why does replugging work
I guess it's some kind of a problem with the way your USB port works. I have an external WD too, connected to a USB 3.0 port and definitivly it's not detected at boot, just after windows startup as a USB device.
After some initial wondering about this problem, I decided no to worry more because I use external drive for data backup and if it is not detected by BIOS makes no difference.
It might be a problem of an outdated BIOS or the USB port's driver. In my case, boths, BIOS and USB 3.0 are rather old.
You can do some reading about issue if you do a ggogle search for issue
USB 3 0 external Hard Drive not detected after Intel Communities
External USB 3 0 HDD is not detected in Windows after boot Help
Aug 06, 2015 | DMCOM Western Digital Wd Elements Se 1 Tb...
1 tb internal hard drive recognised as 300gb?
Please check it:
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. What is the information of your 1 TB hard drive? Is there any unallocated space?
Mar 02, 2014 | Western Digital WD My Passport Essential...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
My desktop model is Compaq SR5213 with 250G harddisk. Recently, I would add a new internal hard disk (3.5", 1 TB), is it possible? As I don't want to buy a external hard disk. thanks
You can add 1 TB hard as additional to 250 GB Hard disk. You did not need to buy a external hard disk. Both hard disks will work together and make total hard disk space- 1.25 TB.
Aug 04, 2010 | Compaq Presario 5000 PC Desktop
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
My Western Digital 500GB EDD has been making Clicking noise
Here are some options to try: - Purchase an alternate enclosure for your hard disk enclosure in case the circuit board in the WD case has gone bad. - Try accessing the drive via MS DOS window and use CHKDSK command to repair the drive (if you can get it to be recognized). - Try connecting the drive to an alternate PC or even a Mac to see if the drive can be recognized (perform disk repair if recognized).
Feb 10, 2010 | Western Digital My Book Essential Edition...
I have a Acer Hard disk D110 1 TB what should the transfer rate
Acer D110 External Harddisk 3.5" 1 TB
USB 1.1 / 2.0 compatible
480 Mbps max
USB powered
Oct 21, 2009 | Acer Computers & Internet
OS whont start whit WD 1 TB external drive.
You need to set your boot sequence in the BIOS so that it does not include external drives. Basically your computer is trying to load Windows from the external drive instead of its own internal one.
Your motherboard manual is going to help, if you can't manage it by yourself give me a link to your manual or tell me the model of your motherboard and i will show you what you need to change.
Oct 03, 2009 | Western Digital MyBook Studio 1 TB USB...
Western Digital External USB 2.0 80 GB Hard Drive Logo
146 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
