Gigabyte motherboard wont post
Gigabyte s-series motherboard am2 socket with a cpu is a amd a64 x2 4200+65n 1m and stock fan motherboard is ga-ma69g-s3h serial 01 04719331817176 21 sn 0732400683 .vga evga 7600gt 256-p2-n615-tx .harddrive hd 320g\wd 7k 16m sata2 wd3200aaks.mem 1gx2/corsair twin2x2048-5400c4 they are istalled in the first two ddr2 slots and a sata dvd burner lite-0n/lh-20a1l-06lsrt rear case fan/antec pro 120mm dbb 75003/front fan aerocool x-blaster 80mm. ultra wizard ult31795 midtower with ultra atx 500 watt power supply.also a ide asus 52mas cd hook to the ide slot in the motherboard/and a3.5 floppy drive hook to fdd cable side of the motherboard/logitech g15 usb keyboard/kensington opical mouse usb/operating system windows xp home edition with xp2 and all the windows updates and window explorer 7 and widows one care trial download from microsoft and .thats mt system has crashed that i put togher myself and im at a lost and need someones help please..this is what happened first i went into the main bioes and into gigabytes itelget overclocking and change the first two setting and i cant remember what they are now i think they were front systemburst mb intelligent tweaker and changed the the settings /ive tryed clearing the cmos took out the cmos battery for 2-4 minutes and tryed it agine still wont post/so i took everything off the motherboard and only has the cpu and fan 1 stick of ram in number 1 ddr2 slot and hooked the monitor to the onboard ega port for vido and only had the computer specher wire and power wire hook to the motherboard and also the 24 wire and 4 wire for the motherboard powers/put the power plug back into the 500 watt psu and also clear cmos againe turn power on and my cmpaq monitor on and pushed the power button on fans can the cpu ok didnot hear any beep codes from the computer specker and still wont post .so i took the motherboard out and the psu and did the same thing again still wont post no bios screen on my moniter at all no keyboard power or mouse gust the cpu fan running / so i tryed this took out the memery no mem in the motherboard at all the motherboard is not in a computer case and the 500watt power unit are the only thing hooked up on my deskand of course the motherboard power s 24 wire and the 4 wire and the power button wire and the front computer cver power button clear the cmos by pulling the battery again out for at lest 2 minutes put the battery back in the motherboard and againe tryed it still no post and no beep codes//////////this was the first motherboard it happened that i bought from newegg so i paid for a new one and bought a 2 more gskill mem 2meg/and also bought a new computer desk top with a 500wattpsu its radmax smildon extreme atx -612webp black secc steel atx mid tower computer case i have not use it or even put anything in it yet im still useing my ultra case for testing first maybe i should use the new raid max case instead what you think yes or no /////the mem1gx2/g.sk f2-6400cl5d-2gbnq./ and i also bought two new cpus now i have 3 amds duel cores and stock fans two a64 x2 4200 one is a windsore 2.2ghz am2 65w and the other is aa64 x2 4200 brisbane 2.2 ghz am2 65 watt dual core ///////and i bought a amd 64 x2 4800+bristone 2.5ghz socket am2 65 watt dual core/ i think im about feed up with amd cpus and gigabyte motherboard companys can you understand why i am i should have just went and bought a computer at a bestbuy or lowes for how much time and effort and many these people have cost me ..help me if you can how in heaven can this company bad mouth asus computer company when they cant even make parts that work .......
  • 76 Answers
Hi telme simple Problam to shot cut /?- ok what is this
Posted on May 17, 2008
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Posted on Mar 14, 2008
SOURCE: gigabyte motherboard wont post
you have pry more, you have to invoq the god in you life, becose
i't's not posseble.
Posted on Aug 19, 2008
  • 9 Answers
SOURCE: modem issues
1. try removing any other pci dial-up modem if you have any installed and uninstall it's driver or application.
2. try enabling your on-board LAN thru bios setup.
3. try installing or updating your LAN driver.
Posted on Apr 09, 2010
AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+ 3.5MB HD8450WCJ3BGH
That CPU will not work in that motherboard. That motherboard is socket AM3, while the CPU is socket AM2. The sockets are not much different, but they are designed to prevent trying to use a CPU that only supports DDR2 memory in a motherboard that only supports DDR3 memory. You would need to find a motherboard that has socket AM2 to use that CPU.
Jan 09, 2014 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
Does anyone know if I am able to mount an AMD Athlon 64 X2 (3800+ Socket AM2) on the H8SMI-2 ?? For me it is not clear described on the website of Supermicro.
no, this board is only compatible with AMD Opteron 1000 Series AM2/AM3 Cpu's. This board is designed for a server environment, hence the use of the Opteron CPU which is primarily used for server systems. Your CPU is an Athlon series which is mainly for home/business use and will not work with this board.
Feb 17, 2011 | AMD H8SMi-2 Motherboard
Can this mother board support hardware virtualization with amd processor athlon x2 64 3600+ what bios version that is not beta can i put it into my bios thanks
I think you can placed in this mother board.
Just follow socket no, and you need AM2 socket supported processor,here speed not the factor.
For more details follow the bellow link please.When your processeor suport AM2 socket no problem.But don't buy Am3 socket supported processor.It will be wrote down on processor box.
Details for click on link=http://reviews.cnet.com/motherboards/gigabyte-ga-m61p-s3/1707-3049_7-32330110.html#userOpinions
Click on this bellow link also.
http://www.gigabyte.com/products/product-page.aspx?pid=2434#ov
Hope it will help you.
Jan 01, 2011 | Gigabyte GA-M61P-S3 Motherboard
GIGABYTE GA-M61SME-S2 AM2 NVIDIA GeForce 6100 Micro ATX AMD Motherboard Will not post, tried clearing CMOS, moved memory chips around. Still does not post.
Is this a new board? Check the processor to make sure that it is seated properly. You will have to remove the fan and heatsink, but if you put the processor in yourself, it is possible that it didn't seat properly.
Mar 19, 2010 | Gigabyte GA-M61VME-S2 Motherboard
Hello again, Upgrading CPU's
Your board supports socket AM2 CPUs the fastest of which is the AMD Athlon 64 X2 6000+ dual-core processor at 3.1 GHz.
Your motherboard does not accept socket AM3 CPUs.
Dec 15, 2009 | Computers & Internet
Wont startup it is blowing diodes
i realize the topic is a motherboard but please confirm the device you have. if it is the motherboard, check the capacitors surrounding the cpu to see if they are rounded. shut off power and use your finger to feel the tops of them
Oct 06, 2009 | ASUS M2V-MX SE AMD AM2 Socket AM2 2000 MHz...
Amd a64 x2 4 athlon 64 x2 dual core processor & Corsair xms2 2 gb
What we really need to know is the socket type for the AMD. AMD makes sockets 939, AM, AM2, AM2+, AM3, etc. www.newegg.com will be the best friend you could ask for. I highly suggest their expert forums and chats as well, they'll help if someone here doesn't. But either way still need to know what socket that amd is. 5200, or 4200 or something like that is also more descriptive, thats how they ID their products. Mine is an AMD phenom II 920. Good proc.
Apr 19, 2009 | Computers & Internet
i't's not posseble.
Aug 19, 2008 | Intel Motherboard
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
Computers & Internet Logo
898 people viewed this question
David Payne
David Payne
