Question about Pentax Optio 60 Digital Camera
My camera will not work, keeps turning off with new batteries in, lens comes for a second or two and the goes in.error on screen says battery depleted
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 16, 2010
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
I have a hp photosmart M627 camera. When I turn it on, the lens stays in and comes up on screen with a lens error:M627-31. Can you help please.
<div class="solution-text"> <span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.<br><a href="http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html" target="_blank" rel="nofollow"><br>http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html</a><br><br><b>Fix #1:</b> Remove the batteries fromthe camera, wait a few minutes. Put a fresh set of batteries back in(preferably rechargeable NiMH 2500mah or better) and turn the cameraon. If that didn't work, try pressing and holding the Function or OKbutton while turning the camera on. <br><b>Fix #2:</b>If the camera's batteries ran down completely while the its lens wasstill open, the camera may show a lens error or not start properly whennew batteries are installed. Remove the memory card and keep itremoved, then install the new batteries. When you turn the camera onwith the card removed it may come back to life, as this triggers areset in some cameras. Error E30 (for older Canon's) means that youdon't have a memory card installed, so turn it off, slip in the <a href="/support/t5307069-lens_error_lens_not_open#" target="_blank" rel="nofollow">SD card</a>and turn it on one last time </span> </div> <!-- /solution text --> <!-- helpful bar --> <span class="br"></span> <!-- /helpful bar --> <p class="add-comment"> <a id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1_lnkHeader" onclick="javascript:ShowHideForms('ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1');" lang="6652"><br></a> </p>
Aug 24, 2010 | HP PhotoSmart M627 Digital Camera
My digital camera has a lens error
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 24, 2010 | Nikon COOLPIX S570 Digital Camera
Lens error, lens do not open
Jul 14, 2010 | Canon PowerShot A1100 IS Digital Camera
I have a Nikon s220 coolpix and everytime I turn on the camera the lens opens, makes a strange noise and closes - it does this 3 times and then I get a lens error message on the screen. Do you know what is...
Jul 02, 2010 | Cameras
Lens error :0x01110000 That's what it says when
Jun 12, 2010 | Pentax Optio 60 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
Nikon Coolpix L4 Lens error
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Dec 08, 2008 | Nikon COOLPIX L18 Digital Camera
Pentax Optio 60 Digital Camera Logo
76 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
