Question about Hitachi Cameras
When we press the disc eject button the door does not open on the Hitachi DZ-GX5080A camcorder.
    Scholar:
  • 154 Answers
It could well be that the tape or the metal / plastic part that prevents the tape door from being opened accidentaly is bent or broken.
if the memory's on the tape are worthwile the effort bring it i to a specialist repairshop, do not try to open it in any other way than described in the manual of your camcorder
Posted on May 17, 2008
I need User's Manual for Hitachi DZ-GX5080A
http://www.retrevo.com/support/Hitachi-DZ-GX5080A-Camcorders-manual/id/20132ag013/t/2/
Go to the above address and voila! Retrevo.com is just incredible for manuals. I'm beginning to believe that Retrevo has a user's manual for heaven itself, lol.---rick
Oct 02, 2009 | Hitachi DZGX5080A DVD Camcorder
DC power cord
You can finalize the DVD using a computer and a software like Nero.
To get a replacement power cord you can contact Hitachi using the number printed on the owners manual, or use the link below:
Hitachi DZ-GX5080A Battery, Camcorder Chargers, Adapters
Sep 05, 2009 | Hitachi DZ-GX3200A DVD Camcorder
Disc eject on Hitachi DZ-GX5060E will not work
I've just received mine today from Argos Clearance Bargains (http://myworld.ebay.co.uk/argos-clearancebargains/) and had the same problem. I was already compoisng a strong complaint in my mind. Anyway I tried the reset method. Remove battery; open LCD screen;hold in reset buttona few seconds; reconnect battery; set to "off" and eject .... out popped a very dirty DVD-RW.
When I reinsterted it the problem recurred and I solved it the same way. I have now permenently removed the offending DVD and the cover opens and closes fine. I will buy some fresh DVDs this weekend and see if the problem returns.
Watch this space and also let me know how you get on,
Aug 04, 2009 | Hitachi DZ-HS300A DVD Camcorder
Probelm ejecting the dvd from my Hitachi GX3100A
If you go to the Hitachi website, you can download the product manual for your camcorder there.
These are the instructions for opening the dvd door.
1 Press down the DISC EJECT button once and
release it.
A few moments after the ACCESS/PC
indicator blinks, the cover of disc insertion
block will open.
2 Gently open the cover by hand fully until it
stops.
This is the link for the owners manual search: http://www.hitachionlinestore.com/survey/manualsearch.aspx
Hope this helps.
Apr 29, 2009 | Hitachi DZ-GX3100A DVD Camcorder
Hitachi DZ-MV380A NTSC won't eject Disc
I have the same problem, I unfortunately cannot fix it.
Jun 28, 2008 | Hitachi DZ-MV380A DVD Camcorder
Hitachi camcorder model DZ-GX5080A
I have lost my software to download onto my computer for my camcorder. Can I download it from another site? Can i purchase the same cd that came with the camera?
The camera is hatichi dz-gx5080a
Jun 09, 2008 | Hitachi Video Cameras
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
Hitachi-DZ-MV550A
eject the disk and if it it empty just open the cd door. with the lense to the left and the door on the top. look into the device. You will see to the left side a metal platform that houses the dvd laser. take and push the platform all the way to the left. The platform fails to retract once you do this you should be able to use a disk like normal provide you have a dvd-r disk.
Nov 26, 2006 | Hitachi DZ-MV580A DVD Camcorder
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
Hitachi DVD camcorder
The door might be stuck. Try "helping" it open manually after pressing the eject button. Otherwise, something is probably broken and you might have to call a repairman.
Apr 09, 2006 | Hitachi DZ-MV580A DVD Camcorder
Cameras Logo
95 people viewed this question
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
