Question about Xerox DocuColor 12 Printer
Xerox c525a Error light blank display
Printer cannot print , with consistant lighted error indicator . Upon turning it off and on , the start up sequece of turning sound is normal. Is the CPU inside corrupted . would it cost 3/4 of the price of a new printer to repair myself
  • 300 Answers
I think you have a problem with the 3.5v LVPS
Posted on May 17, 2008
Unable to close Cover E of Fuji Xerox c525a
For anyone smashing their head against the wall about this problem I finally found out what the issue is in regards to the C525A Cover E not closing.
If you run into this issue you need to look inside the printer where Cover E is, at the very bottom of this is a piece which looks like the rest of the printer but actually freely moves up and down on a swivel. Put it in the up position and as you go to close it it'll fall down again but this time Cover E will close. Not banging it shut or punching it, it all clicks back into place nicely.
Nov 19, 2011 | Xerox DocuPrint C525A Laser Printer
Hi, we have a C525A but has not been used for the last 2 years. When I started it today I got an error code 016-370 with message Reboot Printer. I have powered it down and up for several times but didn't...
You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
Keep me posted abt the end result...
Oct 11, 2010 | Xerox DocuPrint C525A Laser Printer
Printer all of a sudden stopped printing, (LED screen out so unable to read errors). Everything was working fine and then it just stopped printing any more jobs, the red light was on the control panel and...
The inverted, blank, or garbled display is pretty common, a new control panel will fix that and is super easy to install and no tools required. Here is a video that shows how.">
Jul 04, 2010 | Xerox Phaser 8550DP Printer
My Fuji Xerox C525A constantly says that the bypass tray is empty when it is not. I have to remove the paper and slide it back in and it will print 2 pages and then I have to remove the paper and slide it...
make sure you have the right paper size settings. The paper loaded in the tray might be shorter than the setting in the document. Check also the output size in printer setting.
May 20, 2010 | Xerox DocuPrint C525A Laser Printer
C525 printer error code 006-370. What does that mean?
This error indicates a motor failure.
The Main controller unit has not received signals from the motor drive sensor within the specified time period.
In many cases this has been caused by a faulty power supply inside the printer.
You will need a technician to fix this
Jan 27, 2010 | Xerox DocuPrint C525A Laser Printer
Why my Fuji Xerox C525A color lazer printer print out not clear?
hi,clean corotron wires,drum unit & mirrors.send me result.
thank you.
Jun 06, 2009 | Xerox DocuPrint C525A Laser Printer
Xerox 3500 blank pages xerox 3450 display flashes
Clear all memory under maintenance will solve this
Feb 05, 2009 | Xerox Phaser 3450DN Laser Printer
Docuprint c525a only prints first 2 pages of document
Change the paper size in the program you are printing from and delete all paper size changes later than the beginning of the document.
Change it on your default printer and anywhere else you can.
Usually it is asking for different size of paper and will display this on the lcd
Jan 20, 2009 | Xerox DocuPrint C525A Laser Printer
Printer feeds through blank piece of A4 fast, followed by another one, slowly
Service error 6A00 Cancel printing and turn the printer off and then back on.
If this doesn’t clear the error, see the printer manual for more detail.
Jun 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error on Xerox C525A ( 004-332 )
Dear Sir,
can you help me out. i've got a Xerox C525A with a error message "010-397". what does this mean? and how can i fix this so i can carry on printing.
Feb 17, 2008 | Dell 3100cn Laser Printer
Xerox DocuColor 12 Printer Logo
63 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
